codymanche Posted February 10, 2012 Share Posted February 10, 2012 Okay so tj fenders are for custom mount and bigger tires, mj,xj, fenders can do the same the only difference I see is one has lights that could be added maybe I just don't understand it Link to comment Share on other sites More sharing options...
Exxon Valdez Jeep Posted February 10, 2012 Share Posted February 10, 2012 TJ rears on all four corners look pretty nice IMHO. Link to comment Share on other sites More sharing options...
FrankTheDog Posted February 10, 2012 Share Posted February 10, 2012 Are you talking about TJ flares? Link to comment Share on other sites More sharing options...
kyleag89 Posted February 10, 2012 Share Posted February 10, 2012 TJ fronts look retarded on an XJ/MJ IMO Link to comment Share on other sites More sharing options...
cody4359 Posted February 10, 2012 Share Posted February 10, 2012 :agree: Link to comment Share on other sites More sharing options...
Boots Posted February 10, 2012 Share Posted February 10, 2012 :agree: x2 Link to comment Share on other sites More sharing options...
xjrev10 Posted February 10, 2012 Share Posted February 10, 2012 Link to comment Share on other sites More sharing options...
ComancheKid45 Posted February 10, 2012 Share Posted February 10, 2012 that makes 5 of us ;) Link to comment Share on other sites More sharing options...
lostissues Posted February 10, 2012 Share Posted February 10, 2012 I don't like the looks of the TJ fronts either so I used 4 rear flairs. Link to comment Share on other sites More sharing options...
Pete M Posted February 11, 2012 Share Posted February 11, 2012 back to the question at hand, the TJ flares mount in a different fashion (easier to remount up higher) and will clear tires a bit better. Link to comment Share on other sites More sharing options...
Backroads Posted February 11, 2012 Share Posted February 11, 2012 Ive done rear TJ flares on the front and back of an XJ before. Fenxers were trimmed and i actually used 3m double sided tape on the rears. Held up great until the day i peeled them off on purpose. The fronts i just marked and drilled a couple holes and used small bolts with washers through the plastif ot the flare and the metal of the fender. The YJ flares arent as wide unless theyre aftermarket. The TJ flares covered 32 11.5 wide tires nicely. Link to comment Share on other sites More sharing options...
codymanche Posted February 11, 2012 Author Share Posted February 11, 2012 So they are just easier to mount from the sounds of and bigger tires. I don't like the look but if I see it with lights on my it could change my mind? :dunno: Link to comment Share on other sites More sharing options...
