mvusse Posted December 23, 2011 Share Posted December 23, 2011 Another thought... is nut breakers... small, very portable... slip it over the nut crank it down.. it splits the nut. Or... breaker bar, find a cheater handle in the yard somewhere and leverage... I upgraded to a 3/4" drive breaker bar as I kept breaking my 1/2" drive trying to get hub nuts off. I have a 6' cheater pipe I take with me (it's bent) and a 36" crow bar to stick in the wheel studs (also bent) to keep it from turning. Hub nuts are still 50/50. Impact works miracles on those, but I can't afford a battery powered one. Last two hubs I got I ended up getting the axle shafts as well because of it. Link to comment Share on other sites More sharing options...
Boots Posted December 23, 2011 Share Posted December 23, 2011 My dad has all sorts of cordless tools, he uses them for work. I used the 18v sawzall to get my bumper, I had to cut through two 3/8" by like 4-1/5" steel plates. I only used one blade and one or two batteries. Cutting oil goes a long ways. If you go slower the battery and blades will last a lot longer. My dad's buddy has a cordless grinder and he says it kills batteries really quick and isn't all that great. It you want the axle bad enough, just take a hack saw. You just need to cut through the tops of the U-bolts then spin them out of the way (with a hammer) so the axle can drop down. USE CUTTING OIL! it helps A LOT. :wrench: Or you could just try unbolting it.... Link to comment Share on other sites More sharing options...
camjeep3 Posted December 24, 2011 Share Posted December 24, 2011 as for jacks i wouldnt think you would need one. Down here all the cars have the wheels off and are up on "jack stands" with an Mj being spring under, the axle will not fall when taken loose. when I got my 8.8 we unbolted the leaf springs and all, sat the axle up against the exloder and off came the springs and off we went... I will say we had a camp generator and a corded impact. When it comes to junk yarding Ive found that your best bet is spare hands and using everything you have available to you Link to comment Share on other sites More sharing options...
pwrliftin Posted December 24, 2011 Author Share Posted December 24, 2011 Its on an xj, thats why I was wondering about the stands Link to comment Share on other sites More sharing options...
DIGMYGP Posted December 24, 2011 Share Posted December 24, 2011 Find a jack in a car or truck . Find a rim that they put under the vehicles. Put rim under bumper and jack on rim and jack vehicle to desired height. Then use more Rims as jack stands . Be safe and good luck. Link to comment Share on other sites More sharing options...
pwrliftin Posted December 24, 2011 Author Share Posted December 24, 2011 That, is a really good idea! Link to comment Share on other sites More sharing options...
pwrliftin Posted December 26, 2011 Author Share Posted December 26, 2011 Well I have a big breaker bar, an arsenal of tools, 2 very large men, and of course my 100 pound soakin wet buddy for most likely support. We attack at dawn! or when pull a part opens! Link to comment Share on other sites More sharing options...
Paul Bruchal Posted December 26, 2011 Share Posted December 26, 2011 Wish you luck in battle? Post pics of your Victory? Link to comment Share on other sites More sharing options...
pwrliftin Posted December 26, 2011 Author Share Posted December 26, 2011 Got-r-done! Post pics probably tomorrow, phone is broke and camera is dead Link to comment Share on other sites More sharing options...
pwrliftin Posted December 26, 2011 Author Share Posted December 26, 2011 here she is! Mileage on the XJ was not even 100k! Link to comment Share on other sites More sharing options...
mvusse Posted December 27, 2011 Share Posted December 27, 2011 NICE! Which one did you find that at? Link to comment Share on other sites More sharing options...
pwrliftin Posted December 27, 2011 Author Share Posted December 27, 2011 Canton, I got it cleaned up now. It was from an 87 with 100k miles. don't look bad at all now :cheers: Link to comment Share on other sites More sharing options...
carnuck Posted December 27, 2011 Share Posted December 27, 2011 If it was auto, it'll be 3.55 and 5 spd had 3.07 Link to comment Share on other sites More sharing options...
DIGMYGP Posted December 28, 2011 Share Posted December 28, 2011 Did you use my idea to liberate the axle? It works on the front too. Just be careful. Link to comment Share on other sites More sharing options...
pwrliftin Posted December 28, 2011 Author Share Posted December 28, 2011 Yea went and found 2 scissor jacks in random cars and worked great. Passenger side as fairly simple, but the driver side was hard, except snapping on of the u bolts. I got a little carried away with the breaker bar Link to comment Share on other sites More sharing options...
