88_mj Posted September 21, 2011 Posted September 21, 2011 So I've been mancheless for quite a while now. I was at my LJY and spotted an amazingly straight 4x4 MJ on the loader about to be prepped for crushing. :eek: Further inspection revealed a 4.0 under the hood and a 5 speed in the floor. I couldn't stand to let this girl go. The wiring was obviously part of the reason the PO had given up on it. The rodents had been working on most of the insulation and had caused some issues. After forking out scrap price for it and a 91 AX tranny I headed home to get a trailer. After two days of wiring (and praying the engine was somewhat ok) it is once again alive and doesn't smoke. I went back to the same JY and to my surprise there was a 99 XJ that had been hit in the rear. Someone had beat me to the header panel but I was more interested in the wiring and interior. I now have the entire XJ sitting at my shop for gutting. And so my project begins. Plans. repair DS floor. The truck spent some time up north 99 interior, front clip and doors. 99 wiring of course bucket seats from XJ a lift is in the future... I will need a job before that happens
camjeep3 Posted September 21, 2011 Posted September 21, 2011 good job saving her! sounds like it should be a good project
JeepinSoldier Posted September 22, 2011 Posted September 22, 2011 Good Save! Looking forward to watching the resto.
SW86 Posted September 22, 2011 Posted September 22, 2011 that thing should of never been near a crusher! look at it. its no junk yard trash. good save
88_mj Posted September 23, 2011 Author Posted September 23, 2011 Ok... So the XJ is an auto. Is the ECM going to be happy without the auto tranny connected? I can't bring myself to go auto. I know I will have to tap the neutral safety switch. What else am I going to run into?
88_mj Posted September 26, 2011 Author Posted September 26, 2011 A little progress over the weekend. Used the XJ for a patch panel Much better :yes: I also got the xj seat brackets welded in and the seats mounted.
88_mj Posted October 5, 2011 Author Posted October 5, 2011 Converted to the hand brake and got the XJ carpet installed. Built a much more sturdy rear console mount while I was at it.
dfreeman616 Posted October 7, 2011 Posted October 7, 2011 the engine computer should be fine from the auto, they have a separate trans computer anyway. also, the park/neutral could be taken care of by hooking up a clutch pedal position switch, or just bypass. your call.
88_mj Posted October 10, 2011 Author Posted October 10, 2011 Thanks, I plan on bypassing the Neutral safety. I will also lose the 4WD indicator light(91 xfr case). Not a big deal. If it bothers me down the road, a micro switch on the shifter will fix that. I'm at the point in the build now where I have to make a bunch of changes to do any one change. Being unemployed gives me plenty of time as long as I can keep it cheap. This is what I have. My currently running 88 short block. '91 HO head, already ported and valves ground. '99 intake and injectors. '99 full wiring harness, short the headliner stuff. someone beat me to that. '99 fenders and doors. AX/15 w/ internal slave. (hey it was free and freshly rebuilt) funny story on that. I picked up a '91 HO engine/tranny and xfr. It had started knocking shortly after it was rebuilt. :hmm: Can't complain about free..... After removal of the oil pan the problem was apparent. :doh: a little blue shop towel sucked up in the pickup. Needless to say the crank and rod bearings are shot. Half of the rod caps were on backwards anyways so at least I got a head and barely run .060" over pistons out of the deal. Job hunting this week so progress will be slow.
88_mj Posted October 12, 2011 Author Posted October 12, 2011 Good save and great start! Thanks man, I have to say, you have one sweet rig.
Comanche County Posted October 12, 2011 Posted October 12, 2011 Good save and great start! Thanks man, I have to say, you have one sweet rig. Thanks brother, its just one big ole expensive contraption. I'm scared of wiring and would probably never test the waters you've plunged well deep into. Sounds like you've got it under wraps though. I'll be following cause I want to see you pull it off and have a kick A MJ.
88_mj Posted February 3, 2012 Author Posted February 3, 2012 So I'm two weeks into the swap. Things are going smooth so far. I will have some pics soon. I have the dash mounted and the wiring harness in. I started mounting the'99 fuel pump to the '88 pickup unit. (will show how in pics) :wrench:
88_mj Posted February 11, 2012 Author Posted February 11, 2012 Dash guts mounted up B pillar ready for new style latch '99 pump in '88 unit
88_mj Posted February 19, 2012 Author Posted February 19, 2012 Nabbed a couple of HP 44's at the LJY. That's for later.
88_mj Posted February 28, 2012 Author Posted February 28, 2012 Good news is I'm now working again!!!!! Bad news is, it's 7 days a week. Progress will suffer for now but money is rolling in..
88_mj Posted May 13, 2012 Author Posted May 13, 2012 Engine and tranny are in. Crossmember lacks an inch to bolt up. Has anyone ran into this? It's an inch behind the rear most set of holes in the frame. I'm just curious before I fab a new crossmember.
