newbs Posted January 9, 2007 Posted January 9, 2007 How much lift is needed to run 35's on a comanche? Does anyone make a lift to be able to do that or do I have to just put one together? Can this be done without fender trimming if not does anyone make aftermarket flares so it does not look like junk?
JOMJ87 Posted January 9, 2007 Posted January 9, 2007 Here is mine I trimmed alot and have TJ flares and also I have around 7"+ lift on there.http://comancheclub.com/forums/viewtopic.php?t=1591 Cole
88swampedmj Posted January 9, 2007 Posted January 9, 2007 i have about 6" or so and iam about to get 35s but mines cut like a birthday cake haha :brows:
87manche Posted January 9, 2007 Posted January 9, 2007 I cut the hell out of mine and it fit 34" swampers on 3" lift.
JOMJ87 Posted January 9, 2007 Posted January 9, 2007 How much did you cut I think I might drop alittle??? if I could go to full stuff and not hit anything. Can I see some Pics. Cole
pingpong Posted January 9, 2007 Posted January 9, 2007 I had to cut mine a lil tooo. :smart: but keep in mind not all tires are the advertised hieght. so try and tell us what brand of tires you are going to use, then we might have a better idea of what you might need to do. But for in order for there to be no cutting.. I would say long arms, and new leafs in the rear.
87manche Posted January 9, 2007 Posted January 9, 2007 34x9.5 swamper with 3" lift, stock flare After cutting: Finished front and rear: They don't rub, I've got hockey pucks in the coil buckets for bumpstops up front, stock bumpstops in the rear.
newbs Posted January 9, 2007 Author Posted January 9, 2007 35x12.5 Pro Comp Mud Terrain, this thing also does not need to be street legal since it will be off road only. Normally I would never use these tires but I am swapping someone some 33 mtr's for them. I know I will need to do a soa but what springs and from were? For the front I would like to keep it all srpings without useing spacers if possible. Also I have a dana 35 right now but only untill I finish my ford 9, wich by the way does anyone know who makes a decent soa kit that that I can put on the axle.
JOMJ87 Posted January 9, 2007 Posted January 9, 2007 Buy the perches from the dodge dealership they are beefy the stock springs can be used and the brake lines can be extended. that should be all you need for the rear I might have missed something but you don't need a kit. the front just buy the pieces you need to match the rear lift since everyone gets diff lift with SOA. I can get more detailed later I'm at work and have soem stuff to do now. Cole
pingpong Posted January 10, 2007 Posted January 10, 2007 soa in the rear is as simple as welding on some spring perches. You wil have to set your pinion angle correctly, but thats not too hard. You might run into some problems with the way the shocks are mounted, but I t can be solved with some tinkering. For the front. You are looking at alot of work to make it work right. Either Drop brackets or long arms so you can position your front axle in the center of the wheel opening. don't forget about a adjustable trac bar. Since you are not worried about it being street legal hack the crap out of it and clear it wit 3"
newbs Posted January 10, 2007 Author Posted January 10, 2007 without haveing to hack it up how much lift would I need?
88MJay Posted January 11, 2007 Posted January 11, 2007 With 35's there is no way you can get them in there without a little trimming no matter how much lift you run. Well.... I suppose you could run 10" of lift and lower your bumpstops by a foot or so. lol Seriously though... around 6" and some minor trimming should get you there without hacking away a ton. I prefer a little less lift and a little more trimming though. Say.... 4.5" of lift and trim to fit.
newbs Posted January 11, 2007 Author Posted January 11, 2007 can you get 4.5 inch springs? I don't mind minor trimming, especially if I can get flares. I guess I can do a soa with an add a leaf to get enough in the back for the 35's
JOMJ87 Posted January 11, 2007 Posted January 11, 2007 I just made a bastard pack out of leaves I had laying around that were a tiny bit more arch. I don't remember what they came from. I trimmed alot in the front cause of flex issues but I flex mine until the springs almost bind.(hopefully I will brake one and can use that to buy some new ones with a little more length) ;) I have a spare froma broke set a XJ had I bought for parts. Anyway If its Trail only just do a real nice trim on it and don't put flares back on they just get ripped off on the trail anyway. I have seen guys roll the sheet metal around the place they cut and it look like it came stock like that. Just a thought on your project. Cole
88MJay Posted January 11, 2007 Posted January 11, 2007 can you get 4.5 inch springs? I don't mind minor trimming, especially if I can get flares. I guess I can do a soa with an add a leaf to get enough in the back for the 35's Yep.... for $99! http://www.performanceoffroadcenter.com/oscommerce/product_info.php?cPath=33_208&products_id=828
Oizarod115 Posted January 11, 2007 Posted January 11, 2007 auto parts stores carry rubber tubing stuff that you can buy thats DIRT CHEAP and use that to cover the bare edge of the cut... looks factory if you cut it in a decent pattern and not a big circle. my brothers is done like this, he had problems with the bare metal cutting into his meats while flexed, problem solved. it looks just like a little black lip around the edge. real clean.
Southen Crawlin Posted January 11, 2007 Posted January 11, 2007 to run 35's on lift alone id say 8in. but 6in with TJ flare conversion will work just as well if not a tad better due to the lower cog. i currently have my 34's still on with 8in lift and at full flex i have bout 1/2 an in till the tires rub. so 35's with correct bump stops installed should work out great.
pingpong Posted January 11, 2007 Posted January 11, 2007 I ran 35's with 6.5 and could have gone taller with some more bumpstopping. I was not afraid to trim though
newbs Posted January 11, 2007 Author Posted January 11, 2007 Thanks to 89MJay I have a source for cheap big springs upfront now I just need to figure out the rear springs. Weld new perches onto the axle I am building up(lol I can't weld) but do some sort of soa on my current dana35 until I finsih my 9" maybe rockroad bolt on soa. Don't think I will be makeing my own "bastard pack" so I need to buy srpings from somewere.
87manche Posted January 11, 2007 Posted January 11, 2007 rusty's has 4" spring packs for SUA use, CW has them, you could use those and a shackle to make the rear match the front.
JOMJ87 Posted January 11, 2007 Posted January 11, 2007 you can use stock springs for the SOA lift in the front you don't need new ones. I wanted more than my initial 6"s so I did a little fanagling to get what I wanted with extra leaves. Good Luck. Cole
