I was wondering if the charcoal canister can be removed and if so how do you bypass it?I will also be removing my cat I want to leave it set up so I can easily put them back on (both cat and canister) I have an 89 renix 4.0 AW4.
why are you removing the charcoal canister? all it does it absorb excess fumes from your gas tank and then allow the engine to burn them off?
He must love the smell of gas fumes while driving. :roll:
Strictly my opinion, except for #2.
Both of your ideas are:
1. Bad
2. Illegal (Federal Law)
3. Unnecessary
:no:
Your truck won't run any better, you won't get any better mileage. Leave the cannister, replace the hoses.
If you remove the cat and get caught...it's a $1,000 fine, at least...so you decide.
No reason to remove the cat unless its clogged (only happens if you've got something majorly wrong with you ENGINE btw) and you don't want to pay to replace it. Which at that point I can understand.
