Let the build begin
comanche.gif This is my 1989 2 wheel drive pioneer that I picked up on sat Jul 2. I have wanted one for a long time got this one for 800.00. It has new tires, clutch,pressure plate and throw out bearing. Other than that its a little rough.
This is the pics of the truck before it came to me.
Now its at my house
'its a little rough', not really you should have seen mind the day it arived, your's looks good and only $800
did you drive it home, or hall it???
the only thing mine had was a good drivetrane and the rest rust, good luck... B...
:wrench: Took the front end off the bumper mount on the driver side was smashed in so i cut it out. Getting ready for the new parts from the very clean 1989 jeep Cherokee that I picked up today. So now I can convert mine to 4wd when i get a manual 4wheel drive trans. GOT LUCKY FINDING A WHITE ONE
I officially got the parts jeep home and the wife can not believe that i am going to strip it o well. I will do the front firsts and then start on the dash changing it from blue to gray and then the seats and console. Then the 4wd swap i have the manual trans that was in it but it lost a few gears so I am going to take my 2wd manual and have the output shafts changed.
  • 3 weeks later...
jamminz.gif Well found this really clean 95 and had to have it. It threw a rod out the bottom of the motor but other than that it is really nice. So the plans are to put the doors on for power windows and locks. Change out my blue interior to the ultra clean gray interior out of the Cherokee. Got a three inch lift coming it will be here Wednesday. Ok now the fun part Taking all the drive train out to make my MJ 4 wheel drive hell ya. Note my MJ is standard and going with the auto thats in the Cherokee.
On the way home
Image Not Found
Image Not Found
At Home
Image Not Found
Image Not Found
Image Not Found
