Herc Posted May 26, 2011 Share Posted May 26, 2011 Ended up having to replace the D35 in my truck, so replaced with a Cry-co 8.25 from a '97 Cherokee. Cut off the old perches & shock mounts and mocked it in, set the pinion angle and tacked in place. Removed axle finished welding everything up proper, a quick coat of paint and put it in the Manche..... This is where I have a problem (i think anyway) looks like I only have 1/2 to 3/4 of an inch of slip from the shoulder of the slip yolk, to the tail cone of the t-case. Will this be enough or should I be shortening the driveshaft? Will be getting a better measurement after I get home, and take it for a quick spin to see if anything is binding. Any thoughts.... questions.... suggestions? All welcome Thanks Truck - 86 LWB 4.0 Auto 3" lift Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 26, 2011 Share Posted May 26, 2011 what mine has and I have a 60 in the rear. Link to comment Share on other sites More sharing options...
mvusse Posted May 26, 2011 Share Posted May 26, 2011 It may be enough, but I doubt it. I would shorten the shaft about an inch. Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 26, 2011 Share Posted May 26, 2011 It may be enough, but I doubt it. I would shorten the shaft about an inch. so the yoke should be pulled out 1.5" at level load? i don't think so. :thumbsup: Link to comment Share on other sites More sharing options...
flint54 Posted May 26, 2011 Share Posted May 26, 2011 RE: "I would shorten the shaft about an inch." :agree: I just went down this path a couple months ago. The 8.25 housing snout is an inch longer than the D35. Got a shaft one inch shorter, all is well. The old shaft did fit, but I was uncomfortable with the lack of remaining travel, and more uncomfortable with the consequences if it should bottom out suddenly with force. Link to comment Share on other sites More sharing options...
mvusse Posted May 27, 2011 Share Posted May 27, 2011 There is not much movement of the yoke with spring articulation, but axle wrap forcing the pinion up makes a HUGE difference and will cause it to bottom out. Especially if you're SOA. Link to comment Share on other sites More sharing options...
Herc Posted May 27, 2011 Author Share Posted May 27, 2011 Axle is still SUA, I moved the 8.25 back to the next hole on the spring perches 1 1/2 inch from where the D35 was. So anyway I took it for a spin down a rough road 20 minute round trip and all was good. Still unsure about the driveshaft though, I would feel better with at least an inch of travel. Thoughts? Opinions? Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 27, 2011 Share Posted May 27, 2011 no more then a inch and you will be fine. Like I said I run soa and have just over 3/4, which if you look at the yoke you can tell where it was before polished and dirty looking. How it should look L To R Stock yokes; 94 XJ 4wd, 93 XJ 2wd, 94 YJ 4wd. All fit AX-15 trans. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 27, 2011 Share Posted May 27, 2011 On my old D35 I had to replace the driveshaft as it couldn't be balanced. I got a Tom Woods custom drive shaft with an extended GM front slip yoke and cut it off so I had 1" of slip yoke travel at rest. It worked fine for normal driving until I floored it going up a hill one day which rotated the pinion. The slip yoke slapped hard into the transmission tailpiece a couple of times until I backed off. No damage done, but I shaved about 3/8" more off the slip yoke and it never did it again. So I'd say, yes, I think you need more than 1" of travel, more like 1-3/8" - 1-1/2". Link to comment Share on other sites More sharing options...
Herc Posted May 27, 2011 Author Share Posted May 27, 2011 Never thought about the differences in slip shafts! Thanks, will check it tomorrow after work. I think mine is like the one on the left in your picture, if I can find ine like the middle that would give me a little more travel....approx an inch :thumbsup: Link to comment Share on other sites More sharing options...
alleydog Posted May 27, 2011 Share Posted May 27, 2011 I like the idea of moving the axle back on the springs. Seems like the tires always move forward a little when you lift it and this just corrects that. Link to comment Share on other sites More sharing options...
Dirteatr717 Posted May 27, 2011 Share Posted May 27, 2011 I'll trade you driveshafts! Mine needs to be about an inch longer... I have a ax15-d44 shaft, I can get a measurement tmrw if you'd like? Link to comment Share on other sites More sharing options...
Herc Posted May 27, 2011 Author Share Posted May 27, 2011 Dirteatr717..... that would work if we were a little closer than 8 hours! But yeah if you could check your measurement and I'll check my truck after work today and post back :cheers: Link to comment Share on other sites More sharing options...
Dirteatr717 Posted May 28, 2011 Share Posted May 28, 2011 I'll be away from my truck until Monday :grrrr: sorry herc I'll get the measurements then... I'll measure from the front where the ears stick out for the yolk to the end of the ears on the rear of the shaft Link to comment Share on other sites More sharing options...
Herc Posted June 1, 2011 Author Share Posted June 1, 2011 Measured the driveshaft tonight 53 3/8 same location as you were using Link to comment Share on other sites More sharing options...
