ekulrenlig Posted December 21, 2006 Posted December 21, 2006 I just changed the oil in my MJ today and started it up to check the fluid. When I pulled out the dipstick I could hear it sucking air down into the tube. Is this normal? I've never noticed it before.
Oizarod115 Posted December 22, 2006 Posted December 22, 2006 ...why were you checking the oil with the truck running? ive always thought that was a truck off/give it a second to settle routine? ?? am i :chillin:
Bounty Hunter Posted December 22, 2006 Posted December 22, 2006 I just changed the oil in my MJ today and started it up to check the fluid. When I pulled out the dipstick I could hear it sucking air down into the tube. Is this normal? I've never noticed it before. Do you get any oil in the air filter?
mike Posted December 22, 2006 Posted December 22, 2006 yea, you don't check engine oil with it running :eek: , you check auto tranny fluid with it running but not the engine oil. you will not get an acutate reading on the dipstick and you might put way too much in or not enough.
BLHTAZ Posted December 22, 2006 Posted December 22, 2006 Yes, it would be normal for it to suck air in that way, and as stated, you should never check the oil while running as it will appear low and you will over fill it if you add more.
ekulrenlig Posted December 22, 2006 Author Posted December 22, 2006 Ok, well I'm allowed to be an idiot every once in a while. I always thought that after you change it you should start it up and check the level and check for leaks. My bad. Do you get any oil in the air filter? I do get a little bit of oil in the air filter.
BLHTAZ Posted December 22, 2006 Posted December 22, 2006 Ok, well I'm allowed to be an idiot every once in a while.No...you're not an idiot by any means. That is actually a quite common misconception that I have seen many times in my years of working on/with vehicles. ;) There is no such thing as a stupid question...especially if it saves you grief/money :D .
