Window weathersrtip (outside rubber) replacement
Remove door panel.... take lower nut off of wing window frame and remove two phillips screws from upper window frame... pull wing window and frame out ... lower window and you will be able to access rubber clips. Took me about a hour and a half and I am slow.
Roll down the window and pull up on the wipe starting at one end. It's held on by three clips that attach to the door.
x2. its easy. if they have been there a while, they can be stubborn.
The stubborn part was what made me do it the way I did it. Plus I wanted to reinsulate my doors .
