foreman1063 Posted April 20, 2011 Share Posted April 20, 2011 88 LWB, 4.0l with a manual tranny. The first 15-20 minutes everything is nice and smooth, after warm up, the clutch jumps and shakes the truck when taking off in 1st gear. The clutch was supposedly replaced right before I bought the truck about 3,000 miles ago. The suggestions I've heard so far are oil from the rear seal getting on the clutch, worn pressure plate or fly wheel needs resurfacing. What do you guys think? It's pretty damn embarrassing going through drive thru's. :oops: Link to comment Share on other sites More sharing options...
kro10000 Posted April 20, 2011 Share Posted April 20, 2011 If you have a RMS leak then that is most likely your problem Link to comment Share on other sites More sharing options...
foreman1063 Posted April 20, 2011 Author Share Posted April 20, 2011 If you have a RMS leak then that is most likely your problem Definitely have a rear main leak. Guess It's time to replace it. :wrench: Thanks Link to comment Share on other sites More sharing options...
jeep10 Posted April 21, 2011 Share Posted April 21, 2011 88 LWB, 4.0l with a manual tranny. The first 15-20 minutes everything is nice and smooth, after warm up, the clutch jumps and shakes the truck when taking off in 1st gear. The clutch was supposedly replaced right before I bought the truck about 3,000 miles ago. The suggestions I've heard so far are oil from the rear seal getting on the clutch, worn pressure plate or fly wheel needs resurfacing. What do you guys think?It's pretty damn embarrassing going through drive thru's. :oops: If you find out let me know... I have the same issue, no chatter and takes off smooth until about twenty mins of running then I get a take off chatter. I have NO oil leaks ! And all mounts are new. Makes you hate stop and go traffic.... But then again I hate stop and go traffic anyway under normal conditions. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 22, 2011 Share Posted April 22, 2011 Mines the opposite, it chatter a little when cold, till it has a little heat in it then its fine for the rest of the day. Link to comment Share on other sites More sharing options...
Eagle Posted April 22, 2011 Share Posted April 22, 2011 First -- the FSM states that the flywheel canNOT be resurfaced. If it needs to be resurfaced, you need to buy a new one. Clutch chatter often results when a driver slips the clutch too much and burns hard spots into the surface. Then, when a new clutch is installed, the surface is uneven in both contact patch and hardness, which causes the chatter. The only fix is a new flywheel. Link to comment Share on other sites More sharing options...
kro10000 Posted April 22, 2011 Share Posted April 22, 2011 First -- the FSM states that the flywheel canNOT be resurfaced. If it needs to be resurfaced, you need to buy a new one. Clutch chatter often results when a driver slips the clutch too much and burns hard spots into the surface. Then, when a new clutch is installed, the surface is uneven in both contact patch and hardness, which causes the chatter. The only fix is a new flywheel. However I am unsure why it cannot be resurfaced, It looked like my original one had a slight taper to it, and I thought that might be the reason, but the after market replacement is completely flat. Link to comment Share on other sites More sharing options...
jeep10 Posted April 22, 2011 Share Posted April 22, 2011 First -- the FSM states that the flywheel canNOT be resurfaced. If it needs to be resurfaced, you need to buy a new one. Clutch chatter often results when a driver slips the clutch too much and burns hard spots into the surface. Then, when a new clutch is installed, the surface is uneven in both contact patch and hardness, which causes the chatter. The only fix is a new flywheel. However I am unsure why it cannot be resurfaced, It looked like my original one had a slight taper to it, and I thought that might be the reason, but the after market replacement is completely flat. It is getting harder to find a place that will resurface here anyway.. I plan of making a clean sweep of it all when I do it and then hopefully I will not have to revisit again in a day or two. Link to comment Share on other sites More sharing options...
NewfieMJ Posted April 22, 2011 Share Posted April 22, 2011 I had my 2.5's flywheel resurfaced . Feels smooth as silk engaging the clutch . Cost me $40 Link to comment Share on other sites More sharing options...
