james750 Posted April 18, 2011 Share Posted April 18, 2011 Right now I am running SOA with a 2'' AAL. The truck sits at a decent height right now with about 6.5'' front and 8'' rear. I was down changing the centering pin in the left rear leaf spring tonight and found out that one of the springs in the pack is broken. I think I am going to replace both sides with some fresh springs. The only stock height springs I am finding are the Metric Ton springs from Hell Creek. Could I add my 2'' add a leaf to these springs and maintain a good ride quality/lift height? Link to comment Share on other sites More sharing options...
Pete M Posted April 18, 2011 Share Posted April 18, 2011 I doubt you'll need the AALs. aftermarket MT packs will likely give you a boost in height over 20 year old stockers. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted April 18, 2011 Share Posted April 18, 2011 So MT springs will fit on a shortbed MJ? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 18, 2011 Share Posted April 18, 2011 MJ MT springs will fit all Comanches. Link to comment Share on other sites More sharing options...
james750 Posted April 18, 2011 Author Share Posted April 18, 2011 Sweet, I guess I'll order up some M/T springs then. Thanks! Link to comment Share on other sites More sharing options...
skidoo_j Posted February 23, 2012 Share Posted February 23, 2012 Sweet, I guess I'll order up some M/T springs then. Thanks! Did you order the HellCreek MT?? Review? Why HellCreek over Motion? Motion also has factory non MT springs too. Link to comment Share on other sites More sharing options...
