littlezeeker Posted April 4, 2011 Posted April 4, 2011 I was thinking about going with six inch lift and 2 or 3 inch body lift on my 86 jeep comanche but i wanted to know how high i could go before in need some new major parts other then shocks and sway bar links ???????????? thanks :wrench:
mnkyboy Posted April 4, 2011 Posted April 4, 2011 how do you plan to body lift a unibody truck? anything past 3" you need to start adding things
mj Mike Posted April 4, 2011 Posted April 4, 2011 mnkyboyanything past 3" you need to start adding things :smart: :agree:
littlezeeker Posted April 4, 2011 Author Posted April 4, 2011 reading the forms more i found out you can't do a body lift but i still see people with these 6 inch lift kit but they don't have much in the kit but shocks springs and and a leaf.
Automan2164 Posted April 4, 2011 Posted April 4, 2011 viewtopic.php?f=2&t=16482&hilit=Body+lift+uni+body Rob L.
littlezeeker Posted April 4, 2011 Author Posted April 4, 2011 I found this i wonder if this would allow for 6 inches http://www.rocky-road.com/xjcad.html
mnkyboy Posted April 4, 2011 Posted April 4, 2011 you could run OEM arms with it but i would recommend aftermarket arms
littlezeeker Posted April 4, 2011 Author Posted April 4, 2011 where did you get you 6.5 lift at and how much was it ??
Automan2164 Posted April 4, 2011 Posted April 4, 2011 Cheap, and big lift are oxymorons. There is no such thing. Start with some 2" spacers in front, some shackles or an add a leaf in the rear. Go from there. Rob
mj Mike Posted April 4, 2011 Posted April 4, 2011 automan2164Cheap, and big lift are oxymorons. There is no such thing. :agree: evean if you use the stock arms you will need a adjustable track bar for 6 inch +
mnkyboy Posted April 4, 2011 Posted April 4, 2011 where did you get you 6.5 lift at and how much was it ?? mines a hybrid lift meaning its a mixture of parts,Imo thats the best way to do it. Do your homework find out exactly what you need/want and buy what you need to accomplish it.
littlezeeker Posted April 4, 2011 Author Posted April 4, 2011 Well I got a 3 inch lift already and i was wanting to add 2 or 3 inch spacers to my my lift but i didnt know if i would have to buy new control arms or not or pitman arm or something lift that i found these http://www.rocky-road.com/xjcad.html and they look like it may put the front end more where it suppose to be before the lift but i wanted more idea's before i lifted it again. this site has the spaces and control arm and more that i would like to use http://www.rocky-road.com/xjsus.html thank you for the help
mnkyboy Posted April 4, 2011 Posted April 4, 2011 Drop brackets are a good idea. I would buy a set of 6" or 6.5" coils and forget the spacers,3" of spacers isnt a good idea and they won't perform like a full coil.
Automan2164 Posted April 4, 2011 Posted April 4, 2011 It doesn't quite sound like your ready to piece together a lift. Visit some sites with quality lift components, and known reputations for a good product, and see what they have for kits. The manufacturers you keep referencing are decent for experienced builders, as they know what is missing and how to make it work. You need something you can unbox, and toss on without worrying about the completeness of it. Check out Rubicon Express, BDS suspension, Iron Rock, OME... Don't cut corners. You @$$ will be riding on it. Literally. Rob
littlezeeker Posted April 4, 2011 Author Posted April 4, 2011 Can anyone send me any links for good lift kits pieced together or kit, on the forms or web ? :wrench:
Automan2164 Posted April 4, 2011 Posted April 4, 2011 http://rubiconexpress.com/Jeep/MJ/Produ ... art=RE6500 Rubicon Express 5.5" Jeep Comanche lift with Spring over... Drachir495 (?) has one on his LWB. $1200 plus shipping, and you still need shocks. Rob
littlezeeker Posted April 4, 2011 Author Posted April 4, 2011 well somewhere in or around 700 or less it mostly not over 1000
Automan2164 Posted April 4, 2011 Posted April 4, 2011 And then what about tires? Thats going to be a big chunk of change too. Rob
mnkyboy Posted April 4, 2011 Posted April 4, 2011 http://roughcountry.com/jeep_mj_6.html this will be your best bang for the buck in a kit. for your price range your gonna have to get this or piece together something like it.
mvusse Posted April 4, 2011 Posted April 4, 2011 I don't see any way a complete kit for 6.5" lift done correctly will fit in your $700 budget, or even under $1000. Control arm drop brackets are not a bad idea if your truck does not go off road, or only sees mud and sand off road. They work great as anchors in the rocks with more damage done by the rocks to the brackets than by the brackets to the rocks.
littlezeeker Posted April 4, 2011 Author Posted April 4, 2011 Thanks and if anyone finds more sites i would be glad too look at them :D
mnkyboy Posted April 4, 2011 Posted April 4, 2011 I've got drop brackets and my truck does great offroad. Lots of people use them offroad even in the rocks. Anything that's gonna contact a drop bracket is also most likely gonna contact a long arm. I don't know about off the shelf brackets but I know it would take a lot to damage mine.
Pete M Posted April 4, 2011 Posted April 4, 2011 what are you doing for gears? how will you be using the truck?
