jeepsouth Posted March 22, 2011 Share Posted March 22, 2011 Bought a new old stock part# 8982200325 wiper delay for 84-87 cherokee off ebay,and installed on my mj-works great. Any body else have on of these? :cheers: Link to comment Share on other sites More sharing options...
1987Comanche Posted March 22, 2011 Share Posted March 22, 2011 I added this option to my '87 and it was well worth the $5 I spent at the jy for the module. Funny thing is that a PO had replaced the multifunction switch with a delay unit and never finished the job. It was literally a 5 minute install :). Where in SC are you? I'm in WNC and LKQ in Greenville is about an hour away. Link to comment Share on other sites More sharing options...
91coMANche Posted March 22, 2011 Share Posted March 22, 2011 Bought a new old stock part# 8982200325 wiper delay for 84-87 cherokee off ebay,and installed on my mj-works great. Any body else have on of these? :cheers: NICE! Did you replace the stalk too? Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 22, 2011 Share Posted March 22, 2011 To convert from manual wipers to delay you need the multifunction switch w. delay (extra wire), the stalk w. delay switch function, and the intermittent module at the harness. You lucked out jeepsouth as two of the three parts were already there. :cheers: Link to comment Share on other sites More sharing options...
jeepsouth Posted March 22, 2011 Author Share Posted March 22, 2011 1987Comanche, i'm in Summerville,about a 20 min. ride up I-26 from Charleston. I did not have to replace the stalk as this delay works independently. Simply plugged in between harness from my stalk switch to harness under dash. The instructions say that it works with "standard wiper wash system only" (base truck) it is a on/off control knob,and delay module combo that mounts under dash. when you rotate the knob to the right to turn it on it starts the wipers at a fast delay ,and the more you rotate it the slower the delay. The wipers stroke fully ,and park at a rate i control! Oh and the stalk switch still works as it did before off,low,high. Will get some pics later today. :cheers: Link to comment Share on other sites More sharing options...
jeepsouth Posted March 22, 2011 Author Share Posted March 22, 2011 Here are some pics- hope they show up! :waving: Link to comment Share on other sites More sharing options...
jeepsouth Posted March 22, 2011 Author Share Posted March 22, 2011 O.k. the first one is... Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 22, 2011 Share Posted March 22, 2011 Ah, okay. Have used similar universal external delay units like that in the past. Didn't know AMC marketed them as a factory part though. :cheers: Link to comment Share on other sites More sharing options...
jeepsouth Posted March 22, 2011 Author Share Posted March 22, 2011 Me neither ,guess i got lucky when i found it. :banana: Link to comment Share on other sites More sharing options...
1987Comanche Posted March 23, 2011 Share Posted March 23, 2011 i'm in Summerville,about a 20 min. ride up I-26 from Charleston. Too bad y'all are clear across the state! Interesting photos of the add on wiper delay. I always figured the only way to do it was to break the steering column down and go the straight OE route. Link to comment Share on other sites More sharing options...
jeepsouth Posted March 23, 2011 Author Share Posted March 23, 2011 This is an oe part ,but a rare one i guess. automan -thanks for fixing my pics :cheers: Link to comment Share on other sites More sharing options...
Sir_Brando Posted March 23, 2011 Share Posted March 23, 2011 def have to keep my eyes out for one. i hate having just Off-Fast-Faster Thanks for the pics Link to comment Share on other sites More sharing options...
jeepsouth Posted March 23, 2011 Author Share Posted March 23, 2011 Good luck in your search, did you use aftermarket cruise ,or factory on you truck? :cheers: Link to comment Share on other sites More sharing options...
Sir_Brando Posted March 23, 2011 Share Posted March 23, 2011 Good luck in your search, did you use aftermarket cruise ,or factory on you truck? :cheers: all the parts were in the truck when i bought it. everything was just laying around in the engine compartment not hooked up. i got rid of some stuff, did some tests, moved some wires around and finally got it goin. I'm not sure what years/trims came with cruise so I'm not sure where all the components are from. Also, so i don't hijack your thread, if you need info on how i troubleshot and fixed it let me know and ill start a thread on it. ive got pictures to go with it. and if anyone has the info on years/trims cruise was available, that would help too. Link to comment Share on other sites More sharing options...
jeepsouth Posted March 23, 2011 Author Share Posted March 23, 2011 I was just curious because i have just bought an aftermarket unit. It comes with instructions ,but if you had some insight that would be helpful too. :cheers: Link to comment Share on other sites More sharing options...
chunks6067 Posted March 24, 2011 Share Posted March 24, 2011 so the factory one is off fast and faster? because mine looks factory on the column and has the thing that twists but its speed is more like off, delay(super duper delayed slow - slow), low, medium. doesent seem to ever go fast wondered if it was just a bad worn part somewhere Link to comment Share on other sites More sharing options...
jeepsouth Posted March 25, 2011 Author Share Posted March 25, 2011 My base model has low high settings on the stalk. If you have stalk delay feature you have an issue if it is not resonably variable with the stalk switch. I have no real experience with stalk delay as i do not have it. My add on delay works well for me. You may have to replace components to get proper function:cheers: Link to comment Share on other sites More sharing options...
