Oizarod115 Posted December 18, 2006 Share Posted December 18, 2006 The big reason for not using the entire Explorer pack alone is that it will lower even a 2wd MJ. I don't understand why you would want to move the shackle mount location? That part is just fine. It's the location of the center pin in the pack that pushes the MJ axle forward in the MJ wheel well. i think he was under the impression that the explorer main leaf was actually to short to use and wouldnt go "the distance" from the eyes. hence re-drilling to make that distance shorter/longer whatever it may need. and ive never heard anything bad EVER about JC whitney plus for 99 bucks they might not be a bad idea to try. Link to comment Share on other sites More sharing options...
pingpong Posted December 18, 2006 Share Posted December 18, 2006 You can redrill the front mount... if you want to use fullsize chevy springs :D Just make sure they line up right :brows: Link to comment Share on other sites More sharing options...
feerocknok Posted December 18, 2006 Share Posted December 18, 2006 You can redrill the front mount... if you want to use fullsize chevy springs :D Just make sure they line up right :brows: Have you tried this? I've got a set of 32x32s laying around. Link to comment Share on other sites More sharing options...
Car RamRod Posted December 21, 2006 Author Share Posted December 21, 2006 I have a question, If I was to get explorer springs to go with the rear, and did a SOA setup, any idea what my lift would be like? thanks Link to comment Share on other sites More sharing options...
Pete M Posted December 21, 2006 Share Posted December 21, 2006 4-5". It's really hard to say because of the variation in leaf packs. Plus no one has done it yet. Care to be a pioneer? :brows: Link to comment Share on other sites More sharing options...
JOMJ87 Posted December 21, 2006 Share Posted December 21, 2006 I don't know Pete maybe like 6-6.5??? I think that might be closer to right. But Pete is right you should be the first to try. :brows: Cole Link to comment Share on other sites More sharing options...
feerocknok Posted December 21, 2006 Share Posted December 21, 2006 I don't know Pete maybe like 6-6.5??? I think that might be closer to right. But Pete is right you should be the first to try. :brows: Cole The Explorer/Manche springs dropped Pete's truck a bit, so SOA wouldn't be as much lift, I don't believe. Link to comment Share on other sites More sharing options...
JOMJ87 Posted December 21, 2006 Share Posted December 21, 2006 true I didnt think of that I had thought they lifted it a bit but I most have been :chillin: or :nuts: well yeah Pete is right. Cole Link to comment Share on other sites More sharing options...
Car RamRod Posted December 21, 2006 Author Share Posted December 21, 2006 h/o lets make sure we're on the same page. explorer packs alone give a substantial drop don't they? I would be a pioneer but I don't know how to lift the front, nor do I have the money and time right now. Link to comment Share on other sites More sharing options...
feerocknok Posted December 21, 2006 Share Posted December 21, 2006 --MJ main --Exp main --Exp #2 --MJ # 3 --Exp overload got Pete 20.75" hub to fender flare. Stock is ~20.50", that's .75" drop. A complete guess on my part would say that an Explorer pack would drop the truck 1.5", and going SOA would net 3.5 - 5" of lift. If you don't want to lift it by going SOA, or just don't intend on lifting it yet, these springs probably wouldn't be a good plan, unless you like sniffing potholes. Link to comment Share on other sites More sharing options...
pingpong Posted December 23, 2006 Share Posted December 23, 2006 You can redrill the front mount... if you want to use fullsize chevy springs :D Just make sure they line up right :brows: Have you tried this? I've got a set of 32x32s laying around. To answaer your question NO.. but I know myt alcans measure 63" so I don't see why It wouldn't work with a lil work. Keep in mind it will ride like poo pooo due to the increased spring rate. I would hook them up to the axle, center said axle and go for it. Disclaimer "anything I tell you to try is to make you think outside the box and to try and make things work. By no means is this an endorsement to be stupid and cut up your DD like I did :brows: " Seriously I would rethink using the Chevy leafs due to the spring rate. I am sure you could get them to work.. but would the pay off be worth it... I don't think so Link to comment Share on other sites More sharing options...
feerocknok Posted December 23, 2006 Share Posted December 23, 2006 Seriously I would rethink using the Chevy leafs due to the spring rate. I am sure you could get them to work.. but would the pay off be worth it... I don't think so Yeah, was just curious if you had tried em since all the Toys run em anymore, but they've got a different frame width. Link to comment Share on other sites More sharing options...
pingpong Posted December 23, 2006 Share Posted December 23, 2006 I think the spring width would be all right... its just the rate would worry me a lil. If I had a stock rear frame I would try it.. if I all ready had the springs. Link to comment Share on other sites More sharing options...
feerocknok Posted December 23, 2006 Share Posted December 23, 2006 I'll check it out some time, prob not till spring, or till I start investing a LOT more money into propane for the heater. Link to comment Share on other sites More sharing options...
