kineticMJ Posted February 23, 2011 Share Posted February 23, 2011 ok.. so I have been around the forum (mostly reading) for a little while so I thought I would share the progress on the project. Started with a 1987 MJ long bed.. All in all it was in really good shape, minimal rust, no frame rust/damage, floor pans had a few small pin holes but nothing serious. I really lucked out in finding this MJ.. Once I got the truck I started pulling it apart, so that I could replace it with my 2000 XJ parts. Instead of flooding the forum with pictures I created a little site that has all of them uploaded in different phases.. right now I am trying to get it running again (changing the gas tank to a fuel cell setup).. Enjoy. http://dl.dropbox.com/u/1413656/mj/mjhomepage.html After getting new rear leafs and switching them to be spring over, the truck has a pretty decent ride height.. can't wait to get it out. Link to comment Share on other sites More sharing options...
terrawombat Posted February 23, 2011 Share Posted February 23, 2011 Looks great! I'm in the process of doing the interior conversion on my MJ. I can see some of the "non bolt-in" work required for the swap in this pic: Do you have any photos of how you attached the top of the dash or the mods you did to the firewall for the newer style steering column? Any idea what you'll be doing for the rear fender flares? Also, I have to ask - if you are going through the time and expense of stripping this truck down for a full repaint, why wouldn't you pull the dents out the bed and tailgate? Link to comment Share on other sites More sharing options...
kineticMJ Posted February 23, 2011 Author Share Posted February 23, 2011 Well I had a friend say he could paint the truck for me, but it had to be the day next so I only had time to prep the body and fix a few things.. I did what I could with it. the dash mod needed a place to mount since it didn't have a spot for the tabs to line up Just a piece of steel welded to make tabs worked great.. If there is something specific you are thinking at mounting let me know and I will try and remember where I put things and how.. Link to comment Share on other sites More sharing options...
terrawombat Posted February 23, 2011 Share Posted February 23, 2011 Thanks for the pic. I'm just looking for different ways to mount the newer style dash. I've got some of the other firewall modifications figured out, but am still undecided on how to mount the upper part of the dash. Link to comment Share on other sites More sharing options...
ricksjeepster Posted February 25, 2011 Share Posted February 25, 2011 Terrawombat : why don't you try to cut off the rear sides of a 97-01 XJ and weld´em to the previously cutted sides of the bed sides of your mj do some minor body work and you will be good to go... Rear bumper ends are a diferent story but you can get it done by using 2 sets of bumper ends ;) just try to ask ivanonlysix about it he done the entire 2001 conversion inside-out and his MJ looks like factory work :cheers: Looks great! I'm in the process of doing the interior conversion on my MJ. I can see some of the "non bolt-in" work required for the swap in this pic: Do you have any photos of how you attached the top of the dash or the mods you did to the firewall for the newer style steering column? Any idea what you'll be doing for the rear fender flares? Also, I have to ask - if you are going through the time and expense of stripping this truck down for a full repaint, why wouldn't you pull the dents out the bed and tailgate? Link to comment Share on other sites More sharing options...
kineticMJ Posted February 25, 2011 Author Share Posted February 25, 2011 just try to ask ivanonlysix about it he done the entire 2001 conversion inside-out and his MJ looks like factory work i did a search for posts made by 'ivanonlysix' and didn't find anything, is there a project post showing his conversation all finished? Link to comment Share on other sites More sharing options...
ricksjeepster Posted February 26, 2011 Share Posted February 26, 2011 Here´s what I found after a quick search... viewtopic.php?f=7&t=20379 let me check on my pc back up to see if I can show you more pics on the process and my mistake actually the post was mine ... :oops: :wrench: Link to comment Share on other sites More sharing options...
Rymanrph Posted February 27, 2011 Share Posted February 27, 2011 I see that the adapter you used for the gas tank sits pretty high. What did you do to clear the bottom of the bed? I'm jealous of the paint; my swap is almost done, but my paint is still very rough. Link to comment Share on other sites More sharing options...
kineticMJ Posted February 27, 2011 Author Share Posted February 27, 2011 Link to comment Share on other sites More sharing options...
kineticMJ Posted August 10, 2011 Author Share Posted August 10, 2011 So finally getting around to putting some finishing touches on the interior... Toughest was trying to find a spot for rear speakers, originally wanted to use the speaker pod from the rear of the 2000 xj, but with the bucket seats sitting higher than the factory bench seat anytime i hit a bump in the road my head hit the speakers.. so crafted a way to mount them behind the seats and angle it enough so that the sound isn't projected straight into the back of the seats And no, the speaker pod is not bolted directly to the rear wall, I utilized the studs that the interior panels attach to and extended a 1" x 1/4" thick piece of steel across the back of the speaker pod. Just need to find/make a panel to cover the curve at the rear of the headliner.. if anyone has a suggestion on how to cover it let me know. Link to comment Share on other sites More sharing options...
huevo83 Posted September 5, 2011 Share Posted September 5, 2011 KIneticMJ... I have a question for you... how is the fuel pump working? does the sender sends the correct fuel capacity? does it works fine? trying to find out whats the best thing to do on my mj... new tank or rebuild the old tank with the ring as you did... thanks in advance Link to comment Share on other sites More sharing options...
kineticMJ Posted September 5, 2011 Author Share Posted September 5, 2011 KIneticMJ... I have a question for you... how is the fuel pump working? does the sender sends the correct fuel capacity? does it works fine? trying to find out whats the best thing to do on my mj... new tank or rebuild the old tank with the ring as you did... thanks in advance its been working fine for me. Make sure you close off the old pump location off good and tight, otherwise you will learn that gas will start to leak when you fill the whole tank up. http://www.genright.com/ProductInfo.asp ... id=APR1000 That is the ring that I used, and it has worked out well for me so far. Link to comment Share on other sites More sharing options...
kineticMJ Posted March 30, 2012 Author Share Posted March 30, 2012 Link to comment Share on other sites More sharing options...
ejndssn Posted March 31, 2012 Share Posted March 31, 2012 nice job on the MJ :brows: where did you get the front bumper from btw welcome to the family Link to comment Share on other sites More sharing options...
kineticMJ Posted April 1, 2012 Author Share Posted April 1, 2012 nice job on the XJ :brows: where did you get the front bumper from btw welcome to the family I got it off of another jeep owner, he said it was a Logan's Metal Product bumper. You can find them at www.loganmetals4x4.com He said he didn't like it on his XJ, but i think it looks great on my MJ. Link to comment Share on other sites More sharing options...
jonb8 Posted April 2, 2012 Share Posted April 2, 2012 Very nice work, I really wanna do a late model conversion one day.... Link to comment Share on other sites More sharing options...
kineticMJ Posted July 23, 2012 Author Share Posted July 23, 2012 Couple updates on the project... Got some bed armor made from http://www.diegosdeals.com (PACIFIER on the forum here) with a spot to mount the hi-lift as well as a way to mount the tonneau cover that is a few inches short for the long bed. Finally removed the drop in liner and did the bedliner kit. The armor is ready to install, the weather has prevented me from finishing it up, hopefully it will stay clear enough to finish it up in a couple of days.. I'll post some picture of the tonneau cover install too once its done. Link to comment Share on other sites More sharing options...
86customanche Posted July 23, 2012 Share Posted July 23, 2012 I like that armour. Looks good :cheers: what part of VA you in? Link to comment Share on other sites More sharing options...
kineticMJ Posted July 30, 2012 Author Share Posted July 30, 2012 I'm up in Fairfax area.. northern VA. finally had a chance to paint and install the rails.. and spare tire is mounted under the bed in the stock location again. Yep, full size spare fits in the stock location, thank you long bed! Spare Tire.. Link to comment Share on other sites More sharing options...
kineticMJ Posted August 16, 2012 Author Share Posted August 16, 2012 So only have one picture right now, but I will get some more up soon... Tonneau cover is finally installed and looking good.. Link to comment Share on other sites More sharing options...
dualthrush2s Posted August 18, 2012 Share Posted August 18, 2012 Sweet lwb lookin forward to seein it being built. how do you like the duratracs so far? what size? Link to comment Share on other sites More sharing options...
simmonsm Posted August 18, 2012 Share Posted August 18, 2012 Great looking truck, what part of virginia are you in? Link to comment Share on other sites More sharing options...
kineticMJ Posted August 18, 2012 Author Share Posted August 18, 2012 I love the duratrac.... They are 33x12.5 r15.... They ride great on road and off road, I don't do anything super crazy offload so they were the right move for me. I'm up in northern va, got some finishing touches left on the truck but it's coming together Link to comment Share on other sites More sharing options...
kineticMJ Posted September 4, 2012 Author Share Posted September 4, 2012 Got the MJ out on the trails for a little while a couple weeks ago.. finally got some pictures back from the trip.. Link to comment Share on other sites More sharing options...
