Rubicon Rims and Tires?
Hey Guys,
I picked up an 88' Comanche a few months ago. It wasnt treated TERRIBLY but slightly neglected. I have pretty much everything back to par, nothing fancy yet. I need new tires badly, the poor thing sat around an aweful lot with the prior owner. I am going to put a lift on eventually but not really in the budget at this point, too much other stuff to worry about. Anyways, does anyone know what years I could use to pull off a set of Rubicon rims and tires? I feel it would give me just a LITTLE more hight, and some decent tires. Craiglisted, it would be roughly the same price as a whole new set of tires, but I would also get some nicer rims!
Those tires are roughly the same size as 31x10.50-15s. They'll fit okay, but you will probably find that the inside shoulders rub against the lower control arms on tight turns. We all have the same problem when running 31s on factory 15" rims, and a lift does NOT cure it.
hmmm... Ok, so.. Suggestions? I definitly can't do the lift just yet, but need the new tires BADLY, I am trying to avoid double dipping for rims and tires. If I can find some fairly cheap rims and tires to get me by, I am ok with that and then buying a new set later on this year. (3-5 Mo. Approx.) But I don't really want to go and spend 800 on tires and then again when I get my lift.
So, upon a little more research 325-75-15 is pretty standard for an MJ?? when i took mine in to get tires (Prices at least) the guy told me I had trailer tires on my truck, most likely the person who sold it did it to keep thier rims and tires or something of that nature. Now I am looking at only about $300, so THANKS! now I know whats actually SUPPOSED to be on there. ha-ha. Well, that will work for me until I get a lift, THEN i will go after my rubicon rims. Thanks guys!
TJ rubicon wheels are very hard to come by. Getting worse every day.. You can run the 17 in JK wheels with a spacer that adapts to the 5 on 5.5 pattern.
Check these out: http://www.mambawheels.com/Mamba_Wheels.htm This is what my 88 2wd is getting this spring.
For some reason I cannot copy paste an outside link. Google search mambawheels.
The wheel size its self should not dictate if you need a lift or not. I am having a hard time understanding why it would, with exception of of backspacing.
I picked up my set of 5 rock rashed Moabs for $200. They need painted.
You should be able to comfortably fit any stock Jeep wheel/tire combo under your truck (JK rubi 32s might not). Worst case scenario you need a budget lift, coil spacers and leaf shackles. I think the budget lift would be cheaper than going with some generic tires for 5 months. Plus you would have your preferred wheel/tire combo on your truck.
To repeat:
They work. I am currently running 31x10.50-15s on an '88 XJ, which has smaller rear wheel arches than the MJ, with NO lift on the original, 287,000 mile suspension.
Just buy the Rubicon tires and wheels. They'll work fine.
