CubsCarAudio
    Denver, CO.
CubsCarAudio's Achievements
  1. sweeeeet... Cool thanks!
  2. How about JK 17's with 31's... found those $300... Any idea where to get the Spacer to adapt the bolt pattern?
  3. I can find those fairly cheap on craigslist (300) do you think it's do-able on the stock suspension or would I need to do the lift in order to make it work without serious rubbing and just eating the tires up?
  4. So, upon a little more research 325-75-15 is pretty standard for an MJ?? when i took mine in to get tires (Prices at least) the guy told me I had trailer tires on my truck, most likely the person who sold it did it to keep thier rims and tires or something of that nature. Now I am looking at only about $300, so THANKS! now I know whats actually SUPPOSED to be on there. ha-ha. Well, that will work for me until I get a lift, THEN i will go after my rubicon rims. Thanks guys!
  5. This was on Factory Suspension? I'd be ok with that. As I said I am trying to find mostly a 3-5 mo. solution so that would work for me.
  6. I can't find anything on craigslist. :-( All i have found is 2007 and newer.
  7. hmmm... Ok, so.. Suggestions? I definitly can't do the lift just yet, but need the new tires BADLY, I am trying to avoid double dipping for rims and tires. If I can find some fairly cheap rims and tires to get me by, I am ok with that and then buying a new set later on this year. (3-5 Mo. Approx.) But I don't really want to go and spend 800 on tires and then again when I get my lift.
  8. Gotcha, ok, so if i understand this, it's almost pointless to get the rims unless I have the lift money? Or just not so big on the tires?
  9. You wouldnt happen to know how big of a tire I can put on those 17's without causing rubbing and such would you?
  10. Excellent! Thanks so much!
  11. Hey Guys, I picked up an 88' Comanche a few months ago. It wasnt treated TERRIBLY but slightly neglected. I have pretty much everything back to par, nothing fancy yet. I need new tires badly, the poor thing sat around an aweful lot with the prior owner. I am going to put a lift on eventually but not really in the budget at this point, too much other stuff to worry about. Anyways, does anyone know what years I could use to pull off a set of Rubicon rims and tires? I feel it would give me just a LITTLE more hight, and some decent tires. Craiglisted, it would be roughly the same price as a whole new set of tires, but I would also get some nicer rims!
