Mudtruck87 Posted February 9, 2011 Posted February 9, 2011 BEFORE AFTER Year, Make, Model. 87 JEEP COMANCHE, unknown model Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0/auto front D30 rear D44 w/ TT and metric ton pkg, long wheel base Build date: (its on the driverside door sticker, in the form of month and year) Sorry but the only part of the sticker that was scratched, was the part with the date Current Location: Region will do, state, and area of state. Hampton Roads, Virginia Status: Is it still on the road, is it in the junkyard? Project awaiting work? Currently on the road and an on going project. Even tied for a daily driver with my 3500 Dodge 5.9 HO Cummins SRW 4x4 Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. I got the truck in March of 2010 from a friend. I paid $150. Good deal if you think a non running truck with a broken frame and completely rotted floors is a good deal. It did have a 3-4 inch lift and 32's. Had bucket seats with floor shifter in a complete center console and black interior. I like to be different and everyone has a wrangler. A Comanche on the other hand is becoming a rare find. Long story short, closed off top of frame under cab with 1/4 steel, new floors, replaced front 2 feet of frame, rebuilt front suspension, rebuilt D44, installed B&M shifter and installed a stack. Since Then I have removed the TT out of the D44 and locked it with a spool. I modified the fenders to make room for 35's, built a custom front bumper to hold the 4 off road lights and the 12500 lb Warn winch, added a triple gauge kit in the center console, added a tach and adj shift light, Cobra 29 with twin sticks, added lights on the custom bedrack to shed light on the bed when off loading gear at the campsite, custom tube doors,new headliner with addition of a sound bar and Custom air intake. Next to come is a total of 8 inches of custom lift to include a triangulated four link in the rear, more custom front and rear bumper work to include tailgate and tire mount. Install his/her style sun roof, cage with 5 point harness. Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. The Comanche is mine and has become a member of the family. I built it to enjoy life by cruising, hitting the trails and playing in the mud. details athttp://www.cardomain.com/ride/3849608/1987-jeep-comanche-regular-cab Thanks for your time and for all the minds that have contributed to this site so we can keep these machines alive.
shelbyluvv Posted February 9, 2011 Posted February 9, 2011 Year, Make, Model. 87 JEEP COMANCHE, unknown model Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0/auto front D30 rear D44 w/ TT and metric ton pkg, long wheel base The 8th position of the VIN says it is a Comanche Base. I think the D44 was swapped into the truck at some point in its life. A Metric Ton Base would have an F in the 8th position. Nice truck either way!
Mudtruck87 Posted February 9, 2011 Author Posted February 9, 2011 Maybe so. Then again some things slip by at the factory. I can follow the history of the truck back about 12 years from previous owners and no one changed it. Either way I'm not restoring it to numbers matching show truck. If anything it will end up with a Mopar V8 and Dodge 1 ton axles for extreme off highway fun. Thanks for looking and for the useful information. Always nice to find people that do research and know what they are talking about.
JMO413 Posted June 27, 2020 Posted June 27, 2020 Body Model JL62 *X8 SEATS - CLOTH LOW-BACK BUCKET -Y1 ADA LIGHT PACKAGE ADL SKID PLATE GROUP AHY APA MONOTONE PAINT PACKAGE AWE SUSPENSION GROUP BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-5SPD AUTOMATIC 5-45RFE DMR 3.55 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ Fog Lamps LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHB HVY DTY/AUX TRANS OIL COOLER NMB ENGINE COOLING - STANDARD DUTY PE4 Colorado Red QE4 Colorado Red SBA POWER STEERING SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJD WHEELS - 15 X 7.0 STYLED STEEL XEA
jdog Posted January 30, 2021 Posted January 30, 2021 Selling Dealer: HALL JEEP-CHRY Virgina Beach, VA
