the manche Posted February 8, 2011 Share Posted February 8, 2011 how much of the rear fenders can you cut out and if you cut to much will the bedsides flop in the wind? Link to comment Share on other sites More sharing options...
mnkyboy Posted February 8, 2011 Share Posted February 8, 2011 Why do you want to cut them? With SOA you will hit the frame before hitting the flairs unless you plan to run huge tires Link to comment Share on other sites More sharing options...
the manche Posted February 8, 2011 Author Share Posted February 8, 2011 the bed is very rusty around the flares I'm just running 33 inch xterains on diy beadlocks Link to comment Share on other sites More sharing options...
mnkyboy Posted February 8, 2011 Share Posted February 8, 2011 You shouldn't have any clearance issues with 33s. I haven't cut one so I don't know how far you can go but I don't think its much. Link to comment Share on other sites More sharing options...
the manche Posted February 8, 2011 Author Share Posted February 8, 2011 ok i just hate the sight of rust Link to comment Share on other sites More sharing options...
Eagle Posted February 8, 2011 Share Posted February 8, 2011 The inner fender wells are welded to the outer skins JUST beyond the flange for the flares. The previous owner of my '88 MJ "trimmed" off the full width of the mounting flange, and about half the length on each side split into two parts -- the inner and outer. So he then "fixed" it with some really terrible booger welds to hold the outer quarter panel to the inner fenders. You really can't safely trim much more than taking off the flare mounting holes. I don't think trimming is necessary at all. Link to comment Share on other sites More sharing options...
mnkyboy Posted February 8, 2011 Share Posted February 8, 2011 Here you can see how much clearance you have. Link to comment Share on other sites More sharing options...
lostissues Posted February 8, 2011 Share Posted February 8, 2011 I cut out a lot, and it flops in the wind a lot also. I had a bunch of rust that I wanted gone and I put on TJ flairs so I had a bit of room to play with. it doesn't look that pretty but it did get rid of a lot of rust. Link to comment Share on other sites More sharing options...
Motion Offroad Posted February 8, 2011 Share Posted February 8, 2011 Do the "cut and fold" method. (photos below show the process on an XJ, but it's identical on your MJ) You simply cut vertical slots in the fender to the body line, and fold them in. That way your not separating the 2 panels. Here is our MJ shown with the cut and fold method with a TJ flare. If you look close you can see that we didn't go back the body line when we mounted the flare. That's a 35" tire on a 6.5" lift (SOA). Link to comment Share on other sites More sharing options...
btm24 Posted February 10, 2011 Share Posted February 10, 2011 How would you re mount a MJ flair If you cut? I'm looking to cut about an inch for rust removal and more flex. I was going to do the same to the front flairs. And thanks Motion for the idea of cutting I was just gonna go at it with a plasma cutter and a template. Brandon Link to comment Share on other sites More sharing options...
webbjeepxj Posted February 10, 2011 Share Posted February 10, 2011 I did this on my wifes jeep ...... came out awesome and clears 31's (XJ). I'm sure it would help on the MJ. http://www.naxja.org/forum/attachment.p ... 1288319201 Link to comment Share on other sites More sharing options...
btm24 Posted February 10, 2011 Share Posted February 10, 2011 very cool thanks for that Brandon Link to comment Share on other sites More sharing options...
