webbjeepxj
Everything posted by webbjeepxj
No Start. 2.5 TBI Renix 1986.
webbjeepxj replied to webbjeepxj's topic in MJ Tech: Modification and Repairs
mmm, so bad coil? -
mmm, Orange I guess. I'll double check it. What would that indicate? -
Compression good, pump primes, fuel at tb. -
So, fuel pump died, replaced it. Ran for about 20 mins then died. Cranks, but no start. I have fuel. I have new CPS (241 Ohms). All Fusible links checked. Fuel pump primes and cracked the line at the TB and its got fuel. Replaced the fuel injector (AUS). Spark at every plug. Any ideas? I love my truck and it ran so well. I've been trouble shooting it for about a month now. Random Pic for Attention. :D
Yea, I hadn't torqued them on, just sinched them up to check fitment.
17s, and xj front springs with 2 inch pucks works to run 32s. It's tight, but no rubbing.
Oh yea and jk wheels wrapped with stock 255s.
Update .... long time waiting. Rear AutoZone shackles, front Rukse pucks, and xj springs. Found out the clunk in the front was a broken spring! Along with very worn sway bar bushings.
A reman 94 amp for mjs with a/c is about $70 with core exchange, seems good. I'll research the rebuild option.
I have an 86 2.5 tbi. No a/c ... would it be possible/good/safe idea to get an 90 amp alt for a/c, and swap the serp pulley for v belt pulley? They appear to be close, except the 9 o clock wire mounting. Webb
Lowering Questions .......
Interesting on the drop axle stuff. .......... I'm not a block fan and will probably do some leaf swapping, I have a extra set of XJ springs amongst some other stuff. I'll take some pix of what I'm working with so you guys can get it out. -
Lowering Questions ............ And I'm back ...... I finished up my degree, got a sweet job, and finally have some cash to finish my Comanche. Its running like a champ, the replacement bed is put on and interior is done. Question ...... will stock XJ shackles fit on the MJ and would that be an ok way to lower it? .... (would it change the drive line too much?) for the front I see that people use rear TJ, or rear ZJ, or WJ springs? Does this work and what drop would I expect. Also I got rid of my DD volvo, but was thinking of snagging a front air dam off of an older 740, has anyone tried to mate up a volvo or some other front end to get that "street" comanche look. Thanks, Andrew
They also have group sales rates ....... http://ecbiz102.inmotionhosting.com/~bu ... oup-sales/
http://ecbiz102.inmotionhosting.com/~bu ... dule-2011/ Thinking the 21st, mud Bogg'n and Tuff Truck'n, tons of XJ's and MJ's to watch, its a blast, I'll post some pix of this past saturday's event. Anyone Interested in the 21st. ......... I might bring a grill and some burgers, etc. and cook out a few hours before the event.
I'm there and I'll bring my MJ Turd ..... might bring the XJ, but anyhow, I'll be there.
Bang, little update ....... its been on hold, but finally finished up all the mechanical stuff, now some body work and paint ....... well maybe not paint, yet .... Oh, and your going to be jealous ....... scored the Ravines for $100, guy wanted $150, which was low and I was really honest and told him it was low, so he said because I was honest that he said $100 will do ......
16in Steelie availability?
webbjeepxj replied to turboxr's topic in MJ Tech: Modification and Repairs
Dude on NAXJA has these ......... 16's off a dodge charger Image Not Found Probably easy to get since people at dealerships have'm laying around, since most chargers have alloys, or something else on them. -
Project Turbo Rally Comanche
webbjeepxj replied to BookspanS's topic in Member Projects: Your Comanches
Looks freaking Awesome! Hope it works out, keep good progress on this build .... Good alternative to the 4.0 swap -
This looks awesome! I've been wanting to check it out for some time now . . . I'll try to get up there
Will an MJ dana 30, ZJ dana 30, TJ dana 30 bolt into XJ's I figure MJs Dana 30s would ...... how about the rest?
Old style MTRs ....... need 1 or 2 33x12.50x15 Need to for the front of my XJ, 1 would be great, looking for a deal. Let me know what you got! Thanks, used obviously, 1/4 tread or better, if less shoot me a pic might take it for a spare. looking in MD, PA, NJ, VA area
Pull the little turd in Red out ....... Might be a little different, but its a big black block in the fuse box.
I'm thinking about this ......... looks pretty good from the previous years pix.
That first one has enough cooling fans to start up a Nebraska wind farm! Totally sick rigs! I'm still working on collecting all the tid bits to run 37s on my XJ, big rigs are cool :D
Not too worried about the title as Maine can tag it and title it, very easily. Yea its def. Vietnam era, and its an M100, Ive seen a few go for crazy money. 1000-2000 grand, just wondering how rare it is? A $200-$300 range offer seems fair. Thanks :D
