koooooooz Posted December 3, 2006 Posted December 3, 2006 this has goota be fix it is buggin me to death on my 91 mj if i am ideling it is fine but if i rev it up to like 2 grand is starts sweeking like crazy and if i spray blet dressing on it it stops 4 a little while and comes back the next day i no it sounds like a cerpintine belt but i was wondering if it could be any thing elz that might just need oil on it or somthing liek that i don't want to just go and replace a part if i don't no for shure it is that you no and if yall think it is that how hard is it to replace it i mean i no how i just want to no how hard it is lol thanks for any help
feerocknok Posted December 3, 2006 Posted December 3, 2006 Maybe the bearing in the alternator. It's not like the belt slipping, right?
Oizarod115 Posted December 3, 2006 Posted December 3, 2006 my brother's idler never stops squealing. he even replaced it.
Pete M Posted December 3, 2006 Posted December 3, 2006 I've found that a bar of soap works better/longer than belt dressing for silencing the squeak in my van. Do make sure that the belt isn't too loose or too tight.
pingpong Posted December 4, 2006 Posted December 4, 2006 when this happened to an XJ I had it was the bearing going bad in the alt
possum Posted December 4, 2006 Posted December 4, 2006 I have it going on right now with mine and the bearings in my alternator are shot. A good way to test this out would be to turn your lights, heater, and any other power accessories you have and see if it gets worse. Mine seems to do it mostly when I am running my elec. fan, The fan draws like 30amps because it is a high performance model, but this puts a load on the alternator and then causes the bearings to get sticky and the belt to slip. If you are gonna replace the alternator go with Powermaster you can get a 100amp alt. for a little over $100 and it is all new construction.
JohnQ Posted December 4, 2006 Posted December 4, 2006 I have an annoying squeaking noise that disapears if I rest my foot on the clutch. :hmm:
87manche Posted December 4, 2006 Posted December 4, 2006 I have an annoying squeaking noise that disapears if I rest my foot on the clutch. :hmm: that's the plastic bushings. A bit of silicone spray on those goes a long way. Mine started squeaking wen it got cold.
koooooooz Posted December 4, 2006 Author Posted December 4, 2006 what are yall talkin bout i would love to fix it cuz everything on my jeep eather leaks or squeaks [/code]
feerocknok Posted December 4, 2006 Posted December 4, 2006 Because no one seems to carry rebuild kits for alternators anymore, you need to buy a new alternator.
Pete M Posted December 5, 2006 Posted December 5, 2006 I have an annoying squeaking noise that disapears if I rest my foot on the clutch. :hmm: that's the plastic bushings. A bit of silicone spray on those goes a long way. Mine started squeaking wen it got cold. I think that could be the through-out bearing too.
feerocknok Posted December 5, 2006 Posted December 5, 2006 I have an annoying squeaking noise that disapears if I rest my foot on the clutch. :hmm: that's the plastic bushings. A bit of silicone spray on those goes a long way. Mine started squeaking wen it got cold. I think that could be the through-out bearing too. :agree:
