Fire4755 Posted December 17, 2010 Share Posted December 17, 2010 I'm lifting my mj and i'm doin it SOA because i have a rear d35 out of an xj that I'm gonna make work for the rear but what other parts am i gonna need for the front and i think the only other thing i need in the back is the brake line extentions and shocks? idk Help please i'm trying to do this cheap. thanks Link to comment Share on other sites More sharing options...
88pioneer Posted December 17, 2010 Share Posted December 17, 2010 XJ an MJ perches are set up differently. If I remember correctly MJ perches sit more inward, so stock XJ perches won't be in the right position Link to comment Share on other sites More sharing options...
Geonovast Posted December 17, 2010 Share Posted December 17, 2010 You CANNOT simply bolt up an XJ axle and make your truck SOA. Not only will this not give you proper pinion angle, but the perches are at a different width. You still need to move the perches, regardless of which axle you use. Even if it looks like it lines up, it doesn't. If you bolt the XJ axle on as-is, you'll be stressing your springs(twisting). They don't like that and could break. Link to comment Share on other sites More sharing options...
Fire4755 Posted December 17, 2010 Author Share Posted December 17, 2010 ok so i have to move the perches over as well Link to comment Share on other sites More sharing options...
kyleag89 Posted December 18, 2010 Share Posted December 18, 2010 Yes, and you may want a slip yoke eliminator. Lifting an MJ that high is not "cheap" at all, you need longer control arms, track bar, sway links, and springs. Then you will need to adjust your alignment. Link to comment Share on other sites More sharing options...
dave92cherokee Posted December 18, 2010 Share Posted December 18, 2010 You CANNOT simply bolt up an XJ axle and make your truck SOA. Not only will this not give you proper pinion angle, but the perches are at a different width. You still need to move the perches, regardless of which axle you use. Even if it looks like it lines up, it doesn't. If you bolt the XJ axle on as-is, you'll be stressing your springs(twisting). They don't like that and could break. While I agree with the pinion angle and moving the perches the XJ perches are not offset as much as the picture shows. I measured the rear 44 in my MJ and the 8.25 from my old 93 XJ and there was only 1" of difference from center to center. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted December 18, 2010 Share Posted December 18, 2010 You CANNOT simply bolt up an XJ axle and make your truck SOA. Not only will this not give you proper pinion angle, but the perches are at a different width. You still need to move the perches, regardless of which axle you use. Even if it looks like it lines up, it doesn't. If you bolt the XJ axle on as-is, you'll be stressing your springs(twisting). They don't like that and could break. While I agree with the pinion angle and moving the perches the XJ perches are not offset as much as the picture shows. I measured the rear 44 in my MJ and the 8.25 from my old 93 XJ and there was only 1" of difference from center to center. Ive seen pics on here where someone has bolted the XJ axle in with no modification, and it really does NOT look good! Maybe its only a half inch per side, but it don't look good installed.... looks half asssed and dangerous. don't do it. And the front will need around 6 inches of lift to match the rear, and will need as previously stated, a minimum of adjustable control arms top and bottom, and should also have control arm drop brackets, or a long arm setup, also an adjustable track bar, longer sway bar links and a professional alignment. Link to comment Share on other sites More sharing options...
Geonovast Posted December 18, 2010 Share Posted December 18, 2010 You CANNOT simply bolt up an XJ axle and make your truck SOA. Not only will this not give you proper pinion angle, but the perches are at a different width. You still need to move the perches, regardless of which axle you use. Even if it looks like it lines up, it doesn't. If you bolt the XJ axle on as-is, you'll be stressing your springs(twisting). They don't like that and could break. While I agree with the pinion angle and moving the perches the XJ perches are not offset as much as the picture shows. I measured the rear 44 in my MJ and the 8.25 from my old 93 XJ and there was only 1" of difference from center to center. I don't care how good it might look, or how little it's "off". These are suspension components. Cutting corners puts your life, your passenger's lives, and other people on the road's lives at risk. Do it right or don't do it. It would have been convenient to for AMC to put the perch width the same, but for some reason they didn't. Link to comment Share on other sites More sharing options...
Pete M Posted December 18, 2010 Share Posted December 18, 2010 We had a member not too long ago who found out one of the potential effects of using an XJ axle unmodified. One leaf was straight up and down like normal and the other had taken on all of the offset. The bushings on that side had completely obliterated themselves. Don't do it. perches are under $20 and welding can be had for a 6-pack. There's no excuse for doing it wrong. Link to comment Share on other sites More sharing options...
Fire4755 Posted December 18, 2010 Author Share Posted December 18, 2010 I'm just gonna cut off the mounts and make it a spring under and do like 3 inch lift save some money and time cause I'm broke. then in a while i'll go back and long arm and spring over. Totally off topic but does anyone know if the brakes in my 88 mj will have to be modified to use front and rear rears out of a 98 xj. its d30/35 and i believe they have abs. Thanks Link to comment Share on other sites More sharing options...
