kawaboy13 Posted December 13, 2010 Share Posted December 13, 2010 I've been trying to figure this out. I drained my oil and put a new gasket on my plug and all. I think it slowed my leak but there is still drips of the oil pan. Also, the transmission is soaked. Whats up with that? Am I hurting stuff? What can I do? I've even retightened my plug. I don't want to strip anything. I'm not sure where these are coming from. Please help.Thanks! Link to comment Share on other sites More sharing options...
SW86 Posted December 13, 2010 Share Posted December 13, 2010 rear main seal or rear of the valve cover and maybe the seal on the drain plug is rotted/torn. Link to comment Share on other sites More sharing options...
91coMANche Posted December 13, 2010 Share Posted December 13, 2010 Looks like rear main seal/pan gasket to me. You may want to look at your oil filter adapter also. Is there a buildup of oil on your oil filter? For pan gasket there is a really good one piece blue Felpro if you have the 4.0. Get a new drain plug as well and you should be set for only a little bit of coin. Link to comment Share on other sites More sharing options...
foreman1063 Posted December 14, 2010 Share Posted December 14, 2010 You probably have one of the rare 4.0l motors that leak from the rear main seal or valve cover gasket. 1 in a million chance that the oil filter adapter o-ring could be leaking too. :smart: Just messing around but every 4.0 I've ever seen leaked at the rear main, including my 04 TJ when it had 3,500 miles. Just one of the very few draw backs to the 4 liter. Link to comment Share on other sites More sharing options...
CRM1988 Posted December 14, 2010 Share Posted December 14, 2010 That's what mine looked like when the rear main started leaking.But the valve cover gasket could be it. Link to comment Share on other sites More sharing options...
jimmy21669 Posted December 14, 2010 Share Posted December 14, 2010 My best advice is to pressure wash everything and then WATCH for where the leak comes from. Things known to leak.... 1) Valve cover gasket 2) Rear main 3) Oil filter o-ring 4) oil sending unit 5) Blow-by Chasing it can be a chore and it is better to find the source. On my 96 XJ, oil was leaking THROUGH the pan due to corrosion and I had to replace the pan itself. In my experience, it LOOKS like the rear main, but again, I recommend cleaning and monitoring. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted December 15, 2010 Share Posted December 15, 2010 If the air filter is soaked with oil, your crank case is running with a positive pressure. This is caused by a plugged/restricted vent line. (The line running from the back of the valve cover to the intake manifold) A crank case running with a positive pressure will try and puke oil out everywhere it can. RMS, VC gasket, air box. Myself, before fixing any oil leaks, I would make sure the crank case is running under negative pressure. Kind of makes sense, pressurize a vessel (engine) with liquid (oil) and it will try and push the liquid out any opening or weak point. Put it under neg pressure like it is supposed to be and the oil tries to stay in the block where it belongs. :smart: Link to comment Share on other sites More sharing options...
