Akula69 Posted December 6, 2010 Posted December 6, 2010 Year / Make / Model 1989 Comanche Pioneer Engine/Trans/Transfer Case/Front Axle/Rear Axle/Wheelbase 4.0L/AW4/None/Solid/Dana44/120" Build Date: 10/89 Location: Marrero, La. Status: Currently at the Pick-n-Pull in Marrero (as of 12/2010) Notes: This truck was found in the yard on 10/2010 with the tailgate and the interior dome lights removed. It was a Virgina truck based upon the paperwork in the glove box. I salvaged most of the rest of the truck including the rear flares, cargo light, interior and engine compartment wiring, engine sensors, dash, tail ights and front cap.
foreman1063 Posted December 15, 2010 Posted December 15, 2010 Does the bed look that good on the other side as well? That appears nicer than most of the Manche's I see on the road. :fs2: Did you pull the rear sliding glass or latch?
JMO413 Posted May 30, 2019 Posted May 30, 2019 *E1 Cloth Bench Seat -H9 135 Zone 35-Washington 1AA U.S. Dealer Retail 5AM Largo Tracking 5KM AMES Department Stores ADA Light Group ADB Protection Group ALM Longhorn Southfork Package APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CLA Front Floor Mats CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3E STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Door Armrest Storage Lamp LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LPE Cargo Lamp MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver MMP MOLDING - DOOR EDGE GUARDS NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank NHM Speed Control PE8 DARK VIVID RED PRIMARY PAINT - HE8 QE8 DARK VIVID RED SECONDARY PAINT - HE8 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Body Model TM61 Build Date 10/5/88
