87Chief Posted December 3, 2010 Share Posted December 3, 2010 I was doing my gauge cluster swap when... my speedometer cable came up with the cluster... I pulled it all the way out and I found that it has a square end to it... I can't get this thing out from behind the speedometer itself... Any help? Link to comment Share on other sites More sharing options...
Akula69 Posted December 3, 2010 Share Posted December 3, 2010 It should just pull out...but if it simply refuses to budge you could try a very small amount of PB blaster. Think about spraying the PB into a small cup and then using a toothpick to drip it onto the connection. Link to comment Share on other sites More sharing options...
mjeff87 Posted December 3, 2010 Share Posted December 3, 2010 there's two little plastic "tangs" on either side of that white plastic connector there.....squeeze them and the white piece will disengage from the back of the speedo. Jeff Link to comment Share on other sites More sharing options...
87Chief Posted December 3, 2010 Author Share Posted December 3, 2010 Ok, and what do I do about the cable that came out? Just fiddle with it until I feel it go back in? If you know what I mean... haha sorry Link to comment Share on other sites More sharing options...
ComancheKid45 Posted December 3, 2010 Share Posted December 3, 2010 sorry to say but i believe the cable is snapped off. it shouldnt have pulled out of the dash like that :hmm: Link to comment Share on other sites More sharing options...
87Chief Posted December 3, 2010 Author Share Posted December 3, 2010 But it's not snapped... I pulled it all out of the hose thing and there is still a square end like the one that goes to the cluster and nothing broken off of the other side.. Link to comment Share on other sites More sharing options...
jimoshel Posted December 3, 2010 Share Posted December 3, 2010 Just push it back in. No harm done. Link to comment Share on other sites More sharing options...
87Chief Posted December 3, 2010 Author Share Posted December 3, 2010 I got it back in but the end thing to the grey tube won't stay back on... Link to comment Share on other sites More sharing options...
dakal Posted December 3, 2010 Share Posted December 3, 2010 ? Link to comment Share on other sites More sharing options...
87Chief Posted December 3, 2010 Author Share Posted December 3, 2010 The speedometer works but the rpm doesn't... All of the gushes were the sAme as my other one. They all went to the same levels so do I need to buy new oil pressure and all? Link to comment Share on other sites More sharing options...
dfreeman616 Posted December 4, 2010 Share Posted December 4, 2010 so you had idiot lights,now you have gauges, correct? the sending units are different for oil pressure and coolant temp, so you'll need different ones. as for the rpm not working, you either have a connection loose on the back of the cluster, or the tach is bad, or a wire problem from the ecm to the gauge. Link to comment Share on other sites More sharing options...
87Chief Posted December 4, 2010 Author Share Posted December 4, 2010 Ok, so I will still need the oil and coolant sensors then? And also, could I just pull another rpm gauge from another cluster and see if that helps? Link to comment Share on other sites More sharing options...
ComancheKid45 Posted December 4, 2010 Share Posted December 4, 2010 Yep but idk how hard they are 2 switch over. Link to comment Share on other sites More sharing options...
