My name is Paul i live in oregon and i run a car audio shop.
I am looking at a mj that was a 2wd and has been converted to a 4wd .
Do any of you have any words of wisdomw for me i am new to mj's but not to jeeps.
I have had more then my share of xj's and yj's.
Is there anything i shold look for any thing i should look for that would make me want to run from this thing.
Its all stock exept for the conversion.
Any help would be great and if this goes threw i will be looking forward to talking to all of you .
If any one needs audio help or wireing ? please pm me
Thank you for any and all help
Paul
if it has a lift how well is it put together, rust on under the rear fender flairs and under the carpet, and whats under the hood. also bed rust. I'm sure i missed a lot but i hope i helped. Btw welcome to the club :wavey:
Brandon
howdy Paul, if you've been around xj's and yj's then you know what to run from. Not much different than an xj, and actually the same from the doors forward.
I have had some really bad luck.
I am more curious about the conversion is there anything to look for there .
Rust I'm not to worrie about i have a body shop that i can take care of most of that .
Its not lifted anymore he took the lift off becouse the lift he had was used and some parts were missing.
or worn out so he put it back to stock hight .
I know the gas tank is in the bed he said he pulled it to make room for a air tank.
Will a xj lift fit a comanche
Grab a spot on the couch, beer is in the fridge. Welcome to the madness.
Things to look out for:
BA 10/5 manual transmission
Rust/rot over the rear wheels
Rust/rot on the cab corners
Rust/rot on the rockers
Floorboards are notorious rusters
Pluses to keep an eye out for:
D44 rear
Cargo light
Factory brush guard
Hidden winch
AX15
The front lift of an XJ will work the same on an MJ, but the rear is a whole 'nother baby. The MJ is spring under, and the springs are more inboard than that of the XJ. So unlike an XJ, you can spring over the rear of an MJ like a YJ, and net some cheap lift.
Rob L. :cheers:
First off , welcome !!!
Second , what year is it ?
What model ?
Do you know anything else about the swap , IE motor year , trans .
Never the less I say buy it , sounds like you have the ability to fix it up anyway .
Thank you all for the info .
The comanche mat not work out
The guy seems to be a flake.
I have been doing as much research as i can and wow
I want one bad now.
So lol if any one has one to get ride of lol
I will keep checking back and seeing what all of you are up to and ill keep you posted as to what i get.
thank you much
Well i got my new rig .
I'm not part of the comache crew but I'm still
part of the jeep clan.
I got a 93 xj.
Its got some good stuff on it.
Flow daddy header (to stock exhast )
Back woods intake ( home made )
Rusty's 4.5" lift
Rusty's adj lowers links
rusty's adj track bar.
31" bighorn's
15x10 american raceing daytona's.
I'm looking for a bunch of stuff so if any one has stuff they
want to get rid of shoot me a pm .
front bumper with winch mount
rear bumper rock slideres roof rack.
and any other goodies.
I'm a traden fool sence most every one I know
is broke as am I
