91' Jeep MJ
/uploads/archive/23e4f65a3d87d0a78c800acfc1aa6a96/0f5fa7061b51b2b5e5df146c70af67b2.jpg
91' 4.0L / 91' AX15 / 91' NP231 w/tera-low & SYE / 91' D30 w/posi-loc / 98' ZJ Aluminum D44 / 3.73 gears / 112.9 Wheelbase / 31.7x10.4R16 BFG KM2's / 98ZJ 16x7 Ultra Star Wheels
Build date: 11/90...but sold as a 91'
Current Location: Grand Junction
Status: Pavement Princess
Current owner: It's all mine I tell ya!
  • 8 years later...
*D4 TRIM STYLE D4 - VINYL BENCH SEAT
-SA CHARCOAL
174 Zone 74-Denver
1AA U.S. Dealer Retail
3VQ Customer Preferred Discount
ALA SE Decor Group
ALK Italia Package
APA Monotone Paint
BAP 75 Amp Alternator
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KDP STRIPE/BADGE/MOLDING COLOR
KWA STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAF High Altitude Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8
QB8 SECONDARY PAINT
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
TZH Michelin Brand Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z64 Left Front Group XIII
Z81 Right Front Spring Group X
Body Model JL61
Build Date 11/18/90
  • 10 months later...
11 minutes ago, COMJNUT said:
That explains a lot, but not why I have a red base paint.
chrysler reused codes over the years so you have to take it with a grain of salt.  :L:  for example, you don't have the SE or the Italia package.
