what is causing battery light to be on?
I can't figure it out i tested the battery (a new battery) with volt meter while engine was off then with it running it had higher volts when running which would indicate the alternator is good? but the light stays on on the dash. I also have new belts and they are nice and tight too.
no it doesnt stays at 14.9 could it be a faulty battery light? or maybe even the alternator before i put the new battery in and the belt was loose it wouldn't stay on while driving now its on all the time
