MJ86YJ90
Everything posted by MJ86YJ90
  1. so this tank shoudl fit??? http://cgi.ebay.com/ebaymotors/Brand-Ne ... 429wt_1167
  2. so any long wheelbase tank will work ? I am keeping my sending unit I am just trying to find a good deal on one. and straps
  3. 35 bucks sounds good would this weekend be a good time to pick it up? thanks
  4. Will a liner from a ranger or s10 or a small pickup fit an mj????
  5. I love the turbines id buy in a second if closer
  6. sorry long bed
  7. I am in need of a bed liner
  8. yea thats a little far Hopefully i can find a set of wrangler of cherokee wheels without 31's on them here for a good price
  9. I just checked that seller he has one here's the link It says for 87 though is the tank different in 86?? http://cgi.ebay.com/ebaymotors/NEW-FUEL ... 1387wt_941
  10. I am looking for some wheels and tires aluminum wheels preferred also a stock radio for an 86
  11. Where is a god place to find a new tank??? While I have the bed off I would like to swap in a new tank
  12. wheres the best place to disconnect the harness? I have everything off except that and I am ready to pull that bed
  13. So I am about to get ready this weekend and strip the Mj down for some new paint...... can the bed be just lifted off with out pulling the tank? also whats some opinions on types of paint??? I was going to go with an acrylic enamel
  14. damn I figured that would be the answer.
  15. I found out that reverse in my tranny is gone. If I wanted a 5 speed what tranny should I look for. Does it have to come from a 2wd? I am thinking a 2wd will be harder to find
  16. so where is the best place to buy the spacers and such? I like the add a leaf idea
  17. this thing is driving me nuts here goes the most up to date testing........... I have the back wheels off the ground the drive shaft doesnt spin while in gear although the back wheels do (I thought the wheels wouldnt spin) and everything spis in neutral noise is only in gear short of the tranny being messed up somehow I'm not sure. I really want to find out the problem but I donot want to pull the tranny :fs1: i feel the clunking in the pedal assembly when it happens I am not sure maybe its the u joints?????
  18. still clunks when moving but only when its in gear..... The clutch grabs good and i hear nothing in the tranny but i can feel the clunking in the pedal...............
  19. well i see nothing loose or broke through the starter hole that could be causing my rubbing problem i am going to throw the starter on and see what happens. I am hoping it was the loose starter that had somethin to do with the rubbing noise
  20. i am wondering if the starter is rubbing on the clutch discthe noise its making sounds like brake pads rubbing on caliper
  21. no i havent put the starter back in yet. I am wondering if the flywheel spins while the tranny is in neutral like while drifting down the driveway. or does it only spin while the tranny is in gear and spinning. My thoughts are if nothing spins while in neutral its that the starter was loose if it does spin then i have more problems.
  22. So I was having that rubbing sound problem a few weeks ago. Well I finally was able to get some time to work on it and the starter motor was so loose I am wondering if that could have been the culprit. Once again it only makes the rubbing noise while in gear. clutch grabs fine. i pulled starter off and a small three hole bracket fell off too, not sure if its just a spacers or what. Would the starter rub on the flywheel or pressure plate if loose while only doing it in gear?
  23. I just saw I posted this in the wanted section. Sorry I think I shoudl have put it in the for sale section. Although I am not interested in selling just trading
