1989 jeep comanche
comanche.gif 1989 JEEP COMANCHE PIONEER SWB I6 4.OL 4X4 5 SEED PICKED IT UP FOR $200 IN PASCO, WASHINGTON RUNS OK ENGINE LEAK SOMEWHERE AND THE FRONTEND SHAKES LIKE CRAZY SURFACE RUST IS ALL I CAN SEE TILL I PULL THE CARPET AND LOOK THE TRUCK IS MAROON WITH RED INTERIOR GOING TO BE MY DAILY DRIVER WILL
BUILD DATE
RATS NEST
INSIDE IS OK HEADLINER IS FALLING DOWN
I FOUND THIS TRUCK IN YAKAMA, WASHINGTON IT HAS A DEATH WOBBLE I FOUND THAT THE WHOLE FRONT END IS LOOSE I HOPE ALL I HAVE TO DO IS TIGHTEND ALL THE BOLTS AND IT WILL BE OK GUESS I'LL SEE
LOOK AT THE BOLTS WHAT DO YOU THINK
For the most part pretty much everything swaps withing the year generations. Front axles are interchangeable, including the 2wd beam axles. 2wd used the same suspension, which makes 4wd swaps very easy. Engines and Transmissions are the same. Rear suspension is completely different. Rear axles are the same, except that the spring perches are in different spots.
If you have questions about the interchangeability of anything specific, don't hesitate to ask.
Welcome. Here are some good reference materials for you:
RENIX Fuel Injection manual http://www.pirate4x4.com/tech/billavista/PDFs/Jeep_Renix_Fuel_Injection_manual.pdf
'88 Electrical Manual, similar but not identical to '89 http://www.comancheclub.com/forums/viewtopic.php?f=9&t=12734&hilit=electrical
Body: pre '97 4-door Cherokees are the same from the front doors forward, except the floor. Front header panel is different for 91-96 than pre 91
Drivetrain: pre-91 all engine components and instrument clusters are the same, in '91 the HO was introduced with electronic speedo, different intake & exhaust manifolds with Chrysler electronics.
A lot of stuff will swap even between pre and post '91. If you have specific questions, just ask.
And don't forget to add your MJ to the registry http://www.comancheclub.com/forums/viewforum.php?f=33
