ricksjeepster Posted October 12, 2010 Share Posted October 12, 2010 has anyone done this before? my 88 MJ (4 Banger) 4 gear tranny is not working properly anymore and I wonder if I can throw in a 91 wrangler 5 speed tranny is it a direct swap? including the tranfer case and everything else??? Thanks for your advise Rick Link to comment Share on other sites More sharing options...
mnkyboy Posted October 13, 2010 Share Posted October 13, 2010 The wrangler t case is clocked a little different but as far as I know it will fit . I know people here have done it Link to comment Share on other sites More sharing options...
Geonovast Posted October 13, 2010 Share Posted October 13, 2010 Direct swap. AX-5 is identical to the AX-4, aside from some minor interior differences, such as having a 5th gear. T-case for a Wrongler is clocked up a bit, but shouldn't be much of a problem. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted October 13, 2010 Share Posted October 13, 2010 ALL PREVIOUS RESPONSES ARE ASSUMING THAT THE WRANGLER IS A 4 CYLINDER ALSO. If the Wrangler is a 6 cylinder none of this will work. Just wanted you to be sure about this before going too far. Link to comment Share on other sites More sharing options...
jimmy21669 Posted October 13, 2010 Share Posted October 13, 2010 I am getting ready to do this to my 87 MJ. Have a 94 YJ AX5 and 231 that is going in. 2nd advantage....EXTERNAL SLAVE!! Link to comment Share on other sites More sharing options...
dasbulliwagen Posted October 13, 2010 Share Posted October 13, 2010 I'm ready to do the same thing to mine, but my donor is from an 86....also external slave! Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 13, 2010 Share Posted October 13, 2010 yup. 4 cyl to 4 cyl 5 speed/4 speed are direct swap. may be input bearing differences because of differences in the input shaft's bearing surface, but nothing that can't be worked around. make sure that you get the slave and bellhousing for the '91. may be the same, but just in case, get that. Link to comment Share on other sites More sharing options...
ricksjeepster Posted October 15, 2010 Author Share Posted October 15, 2010 Thanks to all for your help! and here's another question for yah ... What about a 99´ 4 cyl XJ manual tranny with 5th gear? I know that I'm gonna have to use the 99 flywheel (Because of crank sensor) and clutch set, but i think it could work too... what you guys think? :typing: question is because a friend of mine has one with everything on it , including T-case, so if it is possible it could be better to have the newer installed instead of the 91´ wrangler one.. Rick Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 15, 2010 Share Posted October 15, 2010 You will NOT be using the 99 flywheel. It has different timing windows as it is for an mpfi 4 cyl. You will need the 99 bellhousing, throwout plate and bearing, clutch set, slave cylinder, and master cylinder, and the 99 transfercase can't hurt either. Link to comment Share on other sites More sharing options...
ricksjeepster Posted October 16, 2010 Author Share Posted October 16, 2010 Thanks JeepcoMJ I´ll go for the 99 set up then .... Link to comment Share on other sites More sharing options...
carnuck Posted October 20, 2010 Share Posted October 20, 2010 I have an XJ AX-5/NP207 (I think. Could be a NP231) with 60K on them, but it's in Seattle Link to comment Share on other sites More sharing options...
