TheMagician Posted October 1, 2010 Share Posted October 1, 2010 I have a 1992 Comanche base model and I am looking for a Cargo Light If you have the wiring and switch that will help. I would like to install a cargo/brake light but I am having a hard time trying to find a flush mount setup. If you know where I can find a flush mount cargo/brake light setup please let me know. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted October 1, 2010 Share Posted October 1, 2010 i am actually in the market for one too Link to comment Share on other sites More sharing options...
500 MJ Posted October 2, 2010 Share Posted October 2, 2010 Join the club guys... Link to comment Share on other sites More sharing options...
STERLING STINGER Posted October 2, 2010 Share Posted October 2, 2010 Join the club guys... i did...the comanche club now how about that light? Link to comment Share on other sites More sharing options...
500 MJ Posted October 3, 2010 Share Posted October 3, 2010 :thumbsup: The cargo light wiring is already run in all of our trucks. We just need to get the switch for the light and the light itself. There is a pink wire that runs up along the drivers side B-Pillar to the roof of the cab, on that wire there is a connector for the cargo light. The light itself grounds through the steel body of the truck by using the same screws that hold the light on. To install the light you need to tap into the wires run for the switch by the steering column and install your own switch. The light can be installed in the cab (I bet you could get another light from some other truck in a yard to work too) by drilling a hold in the cab to let the pink wire through and then drilling the holes to attach the light to the cab. The factory light is not a brake light. It only is a cargo light. Link to comment Share on other sites More sharing options...
89Tonto Posted November 28, 2010 Share Posted November 28, 2010 The light itself grounds through the steel body of the truck by using the same screws that hold the light on. To install the light you need to tap into the wires run for the switch by the steering column and install your own switch. The light can be installed in the cab (I bet you could get another light from some other truck in a yard to work too) by drilling a hold in the cab to let the pink wire through and then drilling the holes to attach the light to the cab. Are there any location marks or dimbles in factory sheetmetal to locate light in the exact location? Without pulling down my headliner yet, I didn't know if I could drill from the inside out or if I have to take careful measurerments of three (3) holes from donor MJ. Link to comment Share on other sites More sharing options...
500 MJ Posted November 29, 2010 Share Posted November 29, 2010 There are no markings that I have seen. I just centered mine with a quick measurement and drilled it. Link to comment Share on other sites More sharing options...
bgred2 Posted November 29, 2010 Share Posted November 29, 2010 Is anyone aware of one from another make truck that might fit? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted November 30, 2010 Share Posted November 30, 2010 won't ANY light fit??? Link to comment Share on other sites More sharing options...
WBKrazy Posted November 30, 2010 Share Posted November 30, 2010 the early 90's ford rangers had cargo lights... methinks one of those might work, it looks kind of similar to the mj one.. Link to comment Share on other sites More sharing options...
500 MJ Posted December 1, 2010 Share Posted December 1, 2010 You can make any light work if you want to... I want an MJ one on my MJ though. Link to comment Share on other sites More sharing options...
