Keats Posted November 16, 2006 Posted November 16, 2006 I just bought a comanche for $400. It runs crappy, and has rust, but hell $400 for a winter beater I'll take it. Now it doesn't run for a darn, its pops, sputters, backfires, then hits some kinda powerband and roaches the tires out from under me....what could be wrong? I'm thinking something with the fuel delivery???? It's not the TPS, I checked that today.
Eagle Posted November 16, 2006 Posted November 16, 2006 What year and what engine? With nothing known about the vehicle, my first guess would have to be oxygen sensor. Second guess would be EGR, if you have one.
Stumpy Posted November 16, 2006 Posted November 16, 2006 What year and what engine? With nothing known about the vehicle, my first guess would have to be oxygen sensor. Second guess would be EGR, if you have one. a bad O2 sensor doesnt always trip the check engine light does it?
JOMJ87 Posted November 16, 2006 Posted November 16, 2006 It SHOULD but may not depending on condition from what I have experienced. Cole
Eagle Posted November 17, 2006 Posted November 17, 2006 What year and what engine? With nothing known about the vehicle, my first guess would have to be oxygen sensor. Second guess would be EGR, if you have one. a bad O2 sensor doesnt always trip the check engine light does it? Just noticed that you have an '89. There is no Check Engine light. The only light is the Maintenance Required light, and that's run by a timer to remind you to change the O2 sensor every 80,000 miles. The light usually gets disconnected the first time it turns on, because the factory says it can't be reset and most owners don't feel like buying a new timer.
Oizarod115 Posted November 17, 2006 Posted November 17, 2006 What year and what engine? With nothing known about the vehicle, my first guess would have to be oxygen sensor. Second guess would be EGR, if you have one. a bad O2 sensor doesnt always trip the check engine light does it? Just noticed that you have an '89. There is no Check Engine light. The only light is the Maintenance Required light, and that's run by a timer to remind you to change the O2 sensor every 80,000 miles. The light usually gets disconnected the first time it turns on, because the factory says it can't be reset and most owners don't feel like buying a new timer. ...theres no check engine light in 89s? how odd.
JOMJ87 Posted November 17, 2006 Posted November 17, 2006 I don't know why i didnt mention our trucks don't have'em I didnt even think just answered. :nuts: Cole
Keats Posted November 17, 2006 Author Posted November 17, 2006 Hey sorry for the lack of info...it's got the I6 4.0 L Not sure what's it's deal is now, all it does is click when I try to start it. I was checking the air filter today, and the plug came off the top of the valve cover (only "plug" on the valve cover, in front of the oil cap). How does it fit back on, it's full of grime and what not, but I'm not sure how it fits. Now all it does is turn over a little and click when I try to start it.....Thanks for the replies!
Pete M Posted November 18, 2006 Posted November 18, 2006 If it just clicks it could be a weak battery or corrosion in the cables.
Oizarod115 Posted November 18, 2006 Posted November 18, 2006 if it just clicks you may need to crawl underneath and give the starter a good solid THWACK with a hammer. then try. (if the starter is the problem it should kill the batter after a while of trying.. cause it still pulls alot) at least mine does.
