aperseghin Posted September 15, 2010 Share Posted September 15, 2010 i have an 88 renix automatic efi. its a 4 speed. What trany do i have and what are my options to make it 4wd? Link to comment Share on other sites More sharing options...
Geonovast Posted September 15, 2010 Share Posted September 15, 2010 You have an AW4, and you need a 4wd AW4 to make your truck 4wd. Converting a 2wd trans to a 4wd trans, especially any automatic, is time consuming, costly, and by the time you're done, you'd have pretty much bought a 4wd trans anway. Link to comment Share on other sites More sharing options...
aperseghin Posted September 15, 2010 Author Share Posted September 15, 2010 Ok so if ifind a loaner truck in the yard, I can remove the aw4 tranny and and transfer case and axels etc, and bolt them up behind my engine? Link to comment Share on other sites More sharing options...
Red 1989 MJ Posted September 15, 2010 Share Posted September 15, 2010 Yes, but you have to grab all the parts around the 4wd Don't forget the shifter & linkage for 4wd :D Link to comment Share on other sites More sharing options...
Rustybucket Posted September 16, 2010 Share Posted September 16, 2010 so you can't just, remove the tail housing from your 2wd aw4, and put the transfercase on the aw4 tranny, and collect the rest of the 4x4 parts needed?? Link to comment Share on other sites More sharing options...
Darren Posted September 16, 2010 Share Posted September 16, 2010 Buy a 4x4 Cherokee, swap drivetrains and sell the now 2wd Cherokee, or just part it out. If you're smart you'll actually make money in that process. Link to comment Share on other sites More sharing options...
Geonovast Posted September 17, 2010 Share Posted September 17, 2010 so you can't just, remove the tail housing from your 2wd aw4, and put the transfercase on the aw4 tranny, and collect the rest of the 4x4 parts needed?? Nope. Link to comment Share on other sites More sharing options...
carnuck Posted September 19, 2010 Share Posted September 19, 2010 Unlike old Chevy trans, the AW4 and AX-15 and AX-5 need the output shaft AND the tail cone swapped to make 2wd to 4wd. This requires taking the transmission apart from the front and pulling the output shaft (it goes in through the back of the trans case) to do it. Miteaswell rebuild the trans while you are at it. Link to comment Share on other sites More sharing options...
