1990 Metric Ton Pioneer 4X4 $1300 OBO - (KY) **Price Lower*
Dadinator
The Good:
Straight Body.
Good Tailgate
No Rust
Long Bed.
4.0
AW4
Metric Ton
Runs Good.
Shifts Good.
Jeep Bed Liner
Good bench seat
Extra Transfer Case in pieces. (loose chain)
Good stereo with sub and amp.
Daily driver.
The Bad:
4WD doesn't work. I think the transfer case is OK, it isn't engaging the front axle.
Needs Headliner
205K miles
Needs steering column.
Needs TLC
Air doesn't work.
1 Bad tire, 3 decent.
In Primer mostly.
Asking $1300 OBO.
Image Not Found
by the way, what's wrong with the column? if it's flopping around near the tilt point, there's 4 bolts that probably need to be tightened up. it takes about 1 to 1.5 hours if you have the right tools and there's some info in the DIY section i posted awhile back on it.
  • 4 weeks later...
Lowered price again.
Somebody needs a Comanche.
This thing needs a lot of TLC, but; it is a good solid foundation.
Straight Body, good seat. Motor runs good. Metric Ton.
Come on folks. The son needs the money. Having kid and moving to a car.
MAKE OFFER ! ! !
  • 4 weeks later...
  MySonsComanche said:
Couple of nibbles, but no bites.
Anyone care to make an offer?
:yes:
Yes, I do! Hmm, I am posting here a moment just to tag this in my response list. :D Conveniently, I am supposed to be in Kentucky this Sunday. I will get back to you.
Sorry I couldn't help you out on the truck. I've been looking for one(nearby) to convert mine. I just wasn't interested in converting to auto and I don't like longbeds. Keep it together if you can. Good luck to you, hope this helps your son out.
Archived
