gl1200aman Posted August 13, 2010 Posted August 13, 2010 Did the 90 comanche with the 4.0 I6 automatic and 4x4 have the electric fan or is it only the clutch fan? I could not find the wiring for it like on the 88 5 speed i have. There is also no sensor in the radiator.
ComancheKid45 Posted August 13, 2010 Posted August 13, 2010 To my knowledge the MJ only came with an E fan if it was equipt with A/C from the factory but don't hold me to that :dunno:
ParadiseMJ Posted August 13, 2010 Posted August 13, 2010 My 88 MJ has the wiring for the fan. I have a 5 speed with A/C. I can't say if yours is set up for it. When I got the MJ had no fan. I got a nice curved blade fan off of a 95-96 XJ at the local junkyard. There are certainly mounting spots on the radiator support and you COULD just wire in a fan directly to a switch on your dash. Junkyard fans are about $10-$15. They should have a battery setup to test the fan motor. Pull one, test it, install it, wire it. Good to go.
gl1200aman Posted August 13, 2010 Author Posted August 13, 2010 Yeah min e is the 4.0 with automatic and no a/c. Mounts are there but no wiring. Just wanted to know if it was suppose to have one. Thanks for the info.
MjPioneer Posted August 14, 2010 Posted August 14, 2010 odd, my 89 4.0 came with a E fan and a clutch fan
gl1200aman Posted August 14, 2010 Author Posted August 14, 2010 That's what I thought and that's why I asked. My 88 4.0 with 5 speed and a/c has the elec. fan.
Incommando Posted August 14, 2010 Posted August 14, 2010 My '88 4.0 auto WITHOUT A/c has both fans, but it has the tow package...
james750 Posted August 14, 2010 Posted August 14, 2010 My '88 4.0 auto WITHOUT A/c has both fans, but it has the tow package... Same here...
MjPioneer Posted August 14, 2010 Posted August 14, 2010 I feel like when a Mj rolled off the line they said "F**k it put a E fan in there" Then another would come out and they'd go "Nah not this gal"
