92comanche4x4 Posted August 11, 2010 Posted August 11, 2010 Ok jus got this thing a week ago. i started i did calipers,pads,hoses,rotors,master cyl, hard lines in the front. an about to start to runnin new hard lines to the back an doin new drums, shoes, wheel cyl, than after that I'm gonna do a ford 8.8 and a soa. but here's a pic of it now. ill have more as i go. let me know wut ya think
Bounty Hunter Posted August 11, 2010 Posted August 11, 2010 Looking good, I've got the exact same truck but it's an '89 2.5L 4spd 2wd, same paint as yours but a maroon interior and sunroof. Will be following this thread closely.
Rymanrph Posted August 11, 2010 Posted August 11, 2010 Why do all the brake work in the back if you're going to swap in a 8.8? Mine 1990 started out pretty similar to that about 7 months ago.
92comanche4x4 Posted August 11, 2010 Author Posted August 11, 2010 Looking good, I've got the exact same truck but it's an '89 2.5L 4spd 2wd, same paint as yours but a maroon interior and sunroof. Will be following this thread closely. ya i think this is a 89 titled as a 90 all my brake parts in the front were from a 89. it will be a slow build. Why do all the brake work in the back if you're going to swap in a 8.8? Mine 1990 started out pretty similar to that about 7 months ago. my mom wants me too or i can't drive it and i can't get a petal with the bacl breaks bein crimped off. and its gonna need the hard lines anyway.
HKB3 Posted August 11, 2010 Posted August 11, 2010 a little soap & water should be on the top of your list :thumbsup:
92comanche4x4 Posted August 18, 2010 Author Posted August 18, 2010 ok here's some better pics its clean. and i painted the rims, grill headlight and headlight bezels. and i just ordered up a 4.5in rc aal kit let me know what ya think my little jeep and my dads dually here's wut i traded for the mj
Pete M Posted August 18, 2010 Posted August 18, 2010 please tell me you at least got the "kit" with the drop brackets.
92comanche4x4 Posted August 18, 2010 Author Posted August 18, 2010 please tell me you at least got the "kit" with the drop brackets. actually i changed my mind i was reading about them. i ended up going with 4.5in rough country aal kit
Pete M Posted August 18, 2010 Posted August 18, 2010 good call. :thumbsup: AAL? that sounds like a whole lotta lift from an AAL. got a link?
MancheKid86 Posted August 18, 2010 Posted August 18, 2010 wouldnt it the the soa conversion to get the first 3"inches, then with the aal it would add the extra 1 1/2 inches?
Pete M Posted August 18, 2010 Posted August 18, 2010 SOA gives anywhere from 4.5" up to 6" depending on the state of your leafs. the AAL lift sounds like the XJ version of the lift. The MJ version is probably SOA or possibly full leafpacks.
92comanche4x4 Posted August 18, 2010 Author Posted August 18, 2010 SOA gives anywhere from 4.5" up to 6" depending on the state of your leafs. the AAL lift sounds like the XJ version of the lift. The MJ version is probably SOA or possibly full leafpacks. it was the aal with shacles
92comanche4x4 Posted August 31, 2010 Author Posted August 31, 2010 ok jus picked up some gamblers on ok 30/9.5/ bfg at's on greatlakes4x4 looks a whole lot better. and tonight i started taking the sport truck stichers off here's some pics
92comanche4x4 Posted April 29, 2011 Author Posted April 29, 2011 ok i havent updte in awhile but i stilll got it only thing ive done to it is drive it and put 2in coil spacers on it and cut the fenders here's with the stock 215's on the rear an 30's on the fron with the coil spacers here's fter i cut the fenders in the front and here it is earning its keep
btm24 Posted May 3, 2011 Posted May 3, 2011 I love the lights! :clapping: What happened to the RC 4.5" lift kit? Btw its NOT SOA Front: Lifted coil springs, lower control arms, transfer case drop kit, extended sway-bar links, brake line relocation brackets & hardware. Rear: Add-a-leafs, shackles & hardware. Shocks: Includes (4) Hydro 8000 series shocks. Brandon
92comanche4x4 Posted May 4, 2011 Author Posted May 4, 2011 thanks i think they make it look sweet and i was gonna put it on another mj i had then i sold the truck thn sold this one and the lift and i just bought this one back a few months ago lol long confusing story but i can't keep a truck long :rotf: also have more pics on the way tommarow of swampers I'm buyin in the morning
