amc 20 Q's
how good is an AMC 20??
some guys say its almost better then a 44 but????? I have doubts about that
I can get my hands on AMC 20 and a front dana 44 from a wagoneer both 3.08 gears for 100$
the dana 44 is for leaf springs so won't fit a comanche without some fab work
and before installing the 20 I would rebuilt it anyway I wanna run 4.56
or should I wait for a 44 instead???
your take on this please
Dominic
Waggy (narrow) rears aren't the best MJ axles, since they're only around 58" wide (60" would be better).
D44 vs M20,
D44 has 10 ring gear bolts, M20 has 8 (but they are larger bolts)
D44 = 8.50" ring gear, M20 = 8.875" ring gear.
D44 has smaller pinion gear, D44 = same size pinion as D30, M20 = same size pinion as D60
(can't think of sizes right now, but I'm thinking it's 1.376" vs 1.626" stems.)
D44 has 30sp 1.30" axles, M20 has 29sp 1.25" shafts
In Waggy's, both D44 & M20 have 1-piece axle shafts from the factory,
the 44 housing is probably stronger (typical M20 housings are thin),
but I never pulled apart a Waggy M20 to see.
It's pretty much a wash, but I'd probably take the 44 over an M20 just for parts availability.
The AMC 20 is a beefy axle. The problem was that, as used in the CJs, Waggys, and Javelins and AMXs, the hubs were splined and bolted to the axle shafts and were very prone to stripping the splines and just spinning. The version used in the MJ had one-piece axle shaft/hub assemblies, which removed that problem.
Also, the Waggies had 6-bolt wheels.
I wouldn't do it.
Fighting a losing argument, but the FSJ's used M23's, not M20's. Full sized Waggy's did not use the 2-piece shafts of the M20. The widetrack versions are rumored to have thicker tubes but I have never personally cut one aprt to see. I have seen W/T D44's cut open and they have D44HD tubes.
8.8/9"/M23/D44/29spline 8.25 are arguably so close to each other, with each model having pluses and minuses, that to spend a dime to swap one for the other strictly for a perceived strength increase is probably spending money that should be spent elsewhere. D44 has a smallish pinion shaft: D44 pinion shafts failing are rarely an issue so that is just one of the thousands of "bragging rights" things with little real word application.
If you are updating to get a cheap disc upgrade as well or something like that, it makes more sense. If starting from scratch, I'd pick the one I could get the best deal on and that had the most upgrades.
for starter I got a FSJ 44 on my YJ and I love it
and no its not for a disc conversion the damn thing is about as old as me so no disc there its was just that for a 100$ I tought it was cheap and a good deal to buy
but I also know that if I wait I can get my hands on a 44 for about the same price if I look hard enough
witch I will have to put the same kind of money to rebuilt anyway
I personally like the D44, too. I have had them under at least a dozen rigs, front and/or rear. They are plentiful, cheap, easy to upgrade, and strong enough for 90% of wheelers. If I was replacing a D35 I would probably go 8.8 w/discs or Pete's favorite isuzu D44 ( :D )just because the wheeling around here generally involves some time in mud and muddy drum brakes are no fun. I like my axles like I like my wimmins: cheap and leakin' a little grease.... :brows:
a mid 90s v6 Rodeo will have a rear Dana 44 to match that jeep front 44 and it comes with disks and either 4.10 or 4.31 gears.
Pete;
What's the width and bolt pattern for the mid 90s v6 Isuzu D44?
EDIT: Never mind, found out. It's 1.5 inches narrower and has 6-lug axles. Could work with spacers and redrilling the axles.
i have a amc 20 in my 86 x and it is so far been tuff as nails it. has 4.10 yukon gears and mosser one peice axels . the neet thing is if you can find a wrecked for explorer 94-98 you can use the disk brakes on the 20 with a minor bit of fab ...a 3/16 c spacer between the seal and mounting flange of the mounting bracketfor the caliber will keep the axels in it. ive had this setup for a few years now and love it.towing a trailer (16) foot with 5 atvs is no problem to get moving or stop in a hurry :banana: .
If the M20's biggest issue has been eliminated by a 1 piece axle conversion, it is not uncommon to do a little stitch welding where the tubes go into the 3rd member and to make a simple ( even mitre box version) over-the-3rd-member truss to help the actual M20's weaknesses: spinning the tubes in the housing and bending the tubes. :thumbsup:
Pete;
yup, it matches the grand waggy front dana 44, not our MJ front dana 30. :thumbsup:
Pete;
yeah but like I said before I have a set of FSJ diff under my YJ and they are wide
they would be to wide for the comanche even with stock rims
I had to put 6'' flares to cover the tires on the YJ don't know how much it would take on the comanche
but I don't think 6'' flares would look good on the comanche
  • 8 months later...
