I ran the JKS Quicker Disconnects on my MJ and loved them, but they aren't cheap. I made these for about $40.
I think I'm going to redo the bracket on the swaybar, but other than that I'm real happy with how they turned out. It's amazing how short stock links really are.
how tough is that L bracket? might consider boxing the sides looks like a nice setup other than that
i've been pondering how to make my own too.
I'm not happy with the angle iron bracket up top either. I wanted to make it double shear and mount the top of the link directly below the swaybar. Being at stock height the angle from the axle bracket to directly underneath the bar would have been too steep, so I had to put it just outside the bar on either side. If you have 3" or more of lift, the angle would be better, and I assume you could move it to directly below the bar.
Like I said in the OP I'll be redoing the swaybar side bracket.
Thanks for all the compliments guys.
