clarkerussell Posted October 24, 2006 Share Posted October 24, 2006 OK, So I sourced a 4x4 MJ as a donor to my 1988 4x2 MJ. I'm planning on using the front and rear axles, driveshafts, and transfer case. Since the donor car has 130K+ miles on it, is there anything I should look at replacing while the swap takes place? Should I rebuild anything? Should I be replacing bushing or anything? Thanks in advance. Also, does anyone know the spline count on a stock transfer case from a 1988 4x4 is 21 or 23? Thanks. Clarke Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 24, 2006 Share Posted October 24, 2006 thats a 21 spline case, everythign should be fine at 130k miles... maybe check the axle seals, and replace all fluids... make sure the t-case has ATF not gear oil. the cutoff year was 1990 for 21 spline... everything after is 23 Link to comment Share on other sites More sharing options...
mjeff87 Posted October 24, 2006 Share Posted October 24, 2006 If the tranny is manual, I would replace the clutch components (especially the slave if it's internal). You could also replace the CPS and keep the old one as a spare, since you'll have easy access to it. If the engine is a 2.5L, you might think about replacing the RMS....it only costs about $5. Unlike the 4.0, you HAVE to pull the tranny/flywheel to replace it...no better time than now. Also, there is an expansion plug in the rear of the block, below the head, that you might want to check the condition of and replace if it looks bad. Here's a pic of it, it's a bit past 12 o'clock, partially covered by the flywheel. HTH, Jeff Image Not Found Link to comment Share on other sites More sharing options...
Pete M Posted October 24, 2006 Share Posted October 24, 2006 These 2 MJs have the same engine, yes? Link to comment Share on other sites More sharing options...
clarkerussell Posted October 24, 2006 Author Share Posted October 24, 2006 These 2 MJs have the same engine, yes? Both cars are 1988 MJ's with the 4.0. The donor car is an Automatic, mine is a manual. My plan is to use a newer NV3550 from a 2000 XJ (23 spline, right?) and an NP242 from something else for the full-time 4x4 option. I need to make sure I get a 23 spline NP242 to match the NV3550. Is there an easy way to search for one of these? For instance, are all NP242's 23 spline after a certain year? Also, is the NP231 that's in my donor truck a 21 or 23 spline? Thanks. Link to comment Share on other sites More sharing options...
87manche Posted October 24, 2006 Share Posted October 24, 2006 all HO t-cases will have a 23 spline input. 87-90 AW4 t-cases were 21 spline. I believe that even the puegot had a 23 spline output, I know that all AX-15 trans were 23 spline output. Link to comment Share on other sites More sharing options...
clarkerussell Posted October 25, 2006 Author Share Posted October 25, 2006 all HO t-cases will have a 23 spline input.87-90 AW4 t-cases were 21 spline. I believe that even the puegot had a 23 spline output, I know that all AX-15 trans were 23 spline output. Excellent info. So it looks like as long as I get a 1991 or newer NP242 it should mate up with an NV3550, right? Thanks again! Clarke Link to comment Share on other sites More sharing options...
clarkerussell Posted October 25, 2006 Author Share Posted October 25, 2006 OK, I just heard from my mechanic in North Carolina. He will convert my 4x2 to 4x4, and install my new transmission, for a grand total of $800... I'm pretty sure that's a good price, but I just wanted to bounce it off the group. Clarke Link to comment Share on other sites More sharing options...
JOMJ87 Posted October 25, 2006 Share Posted October 25, 2006 Ds may not work off donor since your not useing that exact setup (could be longer or shorter. Also $800 sounds high to me but i did everything to mine myself so i really don't know about that. If I was you and of course I'm not I would find someone close to you (like Shaw AFB or something) ;) And put everything in that bolts right up one weekend and then get the rest done up at a shop or by another good buddy that might have the means to do it. just my 2 jingles of sense. Then you can take that $800 buy a couple :cheers: for your buddys who helped and do more to the MJ to make it how you want. Good luck on your decision. Cole Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 25, 2006 Share Posted October 25, 2006 puegots have 21 spline cases. Link to comment Share on other sites More sharing options...
clarkerussell Posted October 25, 2006 Author Share Posted October 25, 2006 Ds may not work off donor since your not useing that exact setup (could be longer or shorter. Also $800 sounds high to me but i did everything to mine myself so i really don't know about that. If I was you and of course I'm not I would find someone close to you (like Shaw AFB or something) ;) And put everything in that bolts right up one weekend and then get the rest done up at a shop or by another good buddy that might have the means to do it. just my 2 jingles of sense. Then you can take that $800 buy a couple :cheers: for your buddys who helped and do more to the MJ to make it how you want. Good luck on your decision. Cole I don't understand what you mean by Ds not working... What are Ds? (Please don't say Ds nuts...) Link to comment Share on other sites More sharing options...
clarkerussell Posted October 25, 2006 Author Share Posted October 25, 2006 puegots have 21 spline cases. Peugeot is toast... I'm replacing it with an NV3550... Link to comment Share on other sites More sharing options...
clarkerussell Posted October 25, 2006 Author Share Posted October 25, 2006 I'm assuming I need to get a new clutch since the old tranny is the Peugeot BA10... If so, and I'm getting an NP3550, I'm guessing I need to get a clutch for a 2000+ XJ with a 4.0, right? Thanks in advance. Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 25, 2006 Share Posted October 25, 2006 Probably. But I always make the parts boys check what tranny it actually is ment for... They can look it up if they aren't daft. Oh, and Ds, or DS, or D/S means driveshafts! Link to comment Share on other sites More sharing options...
clarkerussell Posted October 25, 2006 Author Share Posted October 25, 2006 Probably. But I always make the parts boys check what tranny it actually is ment for... They can look it up if they aren't daft. Oh, and Ds, or DS, or D/S means driveshafts! Gotcha... If the NP242 is going to be too big of a pain, I'll just use the NP231 and change out the input shaft... That shouldn't be too hard, should it? Link to comment Share on other sites More sharing options...
JOMJ87 Posted October 25, 2006 Share Posted October 25, 2006 Ok Ill explain why i metioned Drive shaft issues....Let say your current setup contains A transmission and transfer case the in total legnth are 48"s. K now you swap them both out with a different type from a different vehicle. The replacements have a possibility of being different lengths so lets say they are 45"s long. Now you have 3" you have to make up for in D/S length. Now i don't know alot about the tranny you are going with but It is possible its of different legnths. Sorry for the long discription but i wanted to make sure you got what i was saying fully. ;) Cole Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 25, 2006 Share Posted October 25, 2006 The 242 should bolt up like it was ment to be there. Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 26, 2006 Share Posted October 26, 2006 the NV3550 is the same length as a BA10... less than an inch off. (i was gonna do the swap) but i know an auto tranny will need a longer front d/s. 242 shouldnt matter for the front d/s and should only change the rear a little bit... both cases are similar in size i beleive. Link to comment Share on other sites More sharing options...
