onebigmj Posted April 27, 2010 Share Posted April 27, 2010 After kicking myself for selling my last comanche i finally got another one. here's a pic of my old truck. And here's some pics of my new truck. Pretty much the same thing as my last one. 88 swb pionerr 2.5 Ax4 2wd. This one does have power steering at least. Needed a clutch, driver side floor has alittle rust and runs alittle rough but unlike my last truck this one didnt come out of a field after sitting for two years. The truck was a daily driver and has no rust other than the drivers floor so I brought it home. here's some pics from when I got it. Already replaced the clutch and got it inspected. havent got around to the rough idle issue but i did put a center console and bucket seats out of a 94 xj country in it. Everyone with a comanche should have bucket seats. thanks to mfpdm for the write up. I will be doing 4wd swap very soon including a rough country long arm kit, ironrock track bar, rubicon express coils and spring perches for a spring over, 4.56s lockers and an Ax15 swap using a 96 2.5 dakota bellhousing. I'm looking to run 6in of lift and 33s. I already have the parts i just have to get a few more things and I can get to work. I will update as things progress. Right now I'm just driving the truck to work out all the little problems. Thanks for looking. Let me know what you think Link to comment Share on other sites More sharing options...
freakjeep93 Posted April 27, 2010 Share Posted April 27, 2010 looks good. are ya gunna keep the 2.5? Link to comment Share on other sites More sharing options...
onebigmj Posted April 27, 2010 Author Share Posted April 27, 2010 Yep. Gonna use the 2.5. I have all the parts to put an Ax15 behind it. I'm gonna replace all the gaskets and freshen it up a bit. Link to comment Share on other sites More sharing options...
webbjeepxj Posted April 28, 2010 Share Posted April 28, 2010 What r ya doing with the Bench Seat? I see Weedville is near Black Mo state park, I did a bicycle race there last year ..... 80 miles with 9600 feet of climbing, I vowed to never go back, lol Link to comment Share on other sites More sharing options...
-600JeepMJ Posted April 29, 2010 Share Posted April 29, 2010 :cheers: nice MJ Link to comment Share on other sites More sharing options...
Backroads Posted April 30, 2010 Share Posted April 30, 2010 I like the I4...duno why haha Looks like you got a newish rad and a lot of newer hoses under the hood. Thats good stuff! Link to comment Share on other sites More sharing options...
onebigmj Posted April 30, 2010 Author Share Posted April 30, 2010 I like the I4...duno why haha Looks like you got a newish rad and a lot of newer hoses under the hood. Thats good stuff! I kinda like it too. no one expects much from it. Idk why the hoses look new. Most of them are half shot. the rad is newer though. Link to comment Share on other sites More sharing options...
onebigmj Posted May 10, 2010 Author Share Posted May 10, 2010 Small update. Got the truck running correctly after a tps, map and oxygen sensor. Also had a scratch on my roof that was bothering me so i cut it out. Thankfully i found a sunroof to fill the hole. My long arms also showed up along with a few things form advance adapters. Also got my clutch and clutch master cylinder. Got to get a few more things and i can get started on the lift and 4wd conversion. here's a pic of the long arms. Thanks for looking. Link to comment Share on other sites More sharing options...
Dozer11B Posted May 10, 2010 Share Posted May 10, 2010 Nice truck- great start on it. Now you got plenty of stuff to keep you busy! I've been on leave for the past week so I've spent pretty much every day tinkering with mine...... Loads of fun! Good luck and have a blast. Link to comment Share on other sites More sharing options...
Des88MJ Posted May 14, 2010 Share Posted May 14, 2010 Very nice, I got a doner 89 xj limited, putting all the little goodies into my truck. The buckets I have are power. I noticed that where the seats bolt into the floor is different on both trucks. It doesn't look like I can use the power buckets at all :dunno: I see you have the bench seat track brackets removed, they can only be used on manual buckets I assume, because it doesn't look like I can put the brackets on the power seats :doh: Link to comment Share on other sites More sharing options...
