Dozer11B
    Clarksville, TN
  • Interests
    4 wheeling, camping, classic choppers, general debauchery
Dozer11B's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Haha- sounds good. I'm gonna have to do a motor swap on both- think the Wartoad will get the swap first while the Killpig puts me around. All that is about a year off though.
  2. Well the weather was kinda crappy today, so all really did was drill out the broken rivet on the seat bracket and bolt it back together with a grade 8 bolt. I put the seat back in (I'll be buying a new seat soon!), and replaced my beat up tailgate with a net. I also finished the 13 ball shift knob. I'll get a photo of that later. Still needs some refinement..... I did get these in the mail today: Brand new from Edelbrock for $175 guys...... Get some if you are keeping your 2.8L......... I need to do the front brakes and istall the longer brake lines (front and rear), put in the rear aal from Hell Creek, mount a shift boot from some small foriegn pick up in the JY, clean the floor pan up (probably won't patch the holes until after deployment :( ). Also gonna change the diff fluids as well as the trans and tcase fluids.
  3. Haha- yeah I got it out- after I swaed most of it out, I beat it the rest of the way out and when it gave, it didn't go down in the cylinder. I grabbed it with needle nose pliers. The weather was kinda crappy today (drizzling) and so I limited myself to stuff that didn't involve the hood being up. I'll pull the plugs tomorrow and run some anti sieze in there.
  4. replied!
  5. Oh yeah hornbrod- I'm gonna go pick some up tomorrow and pull them all out and apply some to each. This was a big PITA.
  6. Nice truck- great start on it. Now you got plenty of stuff to keep you busy! I've been on leave for the past week so I've spent pretty much every day tinkering with mine...... Loads of fun! Good luck and have a blast.
  7. OK so now that I have defeated the spark plug (viewtopic.php?f=2&t=23283), I will post up the other stuff that I had been doing while waiting for these like PB blaster to take effect.......... I pulled the interior. From the passenger side: Passenger side holes: Driver's side: Driver's Side hole: Rear of cab: Seat bracket studs are good, but seat bracket needs to be fixed or replaced. I also did the cut and fold in the rear fenders to get a little bit more clearance. I started this by removing these four inner mud flaps: Then I set to wire wheeling the inside of the fenderwells. I also used rust-converting primer on some of the bare/rusty spots in there. The brown is just old undercoating It was still black- the lighting is just wierd I guess. I figured leave the stuff that is sticking alone- more is better : Next I used a cutoff wheel on my angle grinder to radius cut the wheel well. You obviously want to cut in between the pinch welds... Some of my cuts were too long- damned grinder jumped on me: Here is an idea of how much more clearance you can get- I had already trimmed the wheel wells a bit: I then beat the notches in with a small ball peen hammer and a three pound sledge: I used a flap disc on the anglegrinder to sand down the chipped areas of the paint. I followed that with some primer and undercoated the entire wheel well and lip on the wheel well: If I could do this mod again, I would have used body sealer before primer and undercoat. I listened to the guy at the auto parts store when he told me "oh undercoat will be thick enough". Lesson learned. I'm not too worried- eventually I will either tub the wels out or remove the bed altogether. Also started a small tool box from an ammo can from work: Not sure if I want to mount it in the bed permanently or make it a grab and go affair. I sanded it down to bare metal with the wire wheel and prmered it black. It got too dark for a good pic so I'll take one tomorrow to letyou see ow it came out....... Have fun and be safe. Thanks for looking!
  8. Hey thanks Jim. I appreciate all the advice from everyone here too. I think this was just an extreme case of neglected spark plugs where extreme measures were called for.
  9. So this is what it looked like: The arrow denotes up in the first shot. So I got a hold of my buddy and explained the situation, and what all I had done to try and break this thing free. He told me to get a small hacksaw blade that will fit inside the hole and saw it out from the inside out. I bought some "midget" hacksaw blades from Home Depot, snapped them in half, and pinched them in needle nose vise grips: So I sawed in two spots about a quarter of an inch apart and eventually I was able to hammer that piece out with a screwdriver: The I sawed another spot opposite of the chunk I took out. After sawing partway through (which left a weak spot in the rest of it), I beat a screwdriver in around the remainder of the spark plug until it loosened up and I could run it out with the EZ out: Then I used this to vacuum the area around the hole as well as down into the cylinder: It is an attachment on the wife's Kirby. I had a piece of rubber hose that I put o there and ran down into the cylinder. I also bumped the cylinder to the top to vacuum that. When I thought I was good, I left the plug out and ran it a couple of times for 10-15 secind each to clear anything else out. This was killing me as I spent nearly a week working on this (I did keep busy with other projects when I couldn't make forward progress on this issue). I really hope this helps someone who may end up in a situation like this.
  10. nevermind- didn't look at it close enough to realize what it is. Gonna need a whole seat.
  11. Hey Threesons thanks. I'll give it a shot. Stay tuned.........
  12. Seems the more I pull this thing apart, the more issues come up......lol. My driver's side seat bracket popped the rivet at the front left and the rear left hole is FUBAR, so I'm looking for the whole driver's side bracket. Also looking for the slide adjustment return spring. Passenger side is gone which means it rocks back and forth under acceleration and braking- FUN! Anyone got anything??
  13. Hey Big Alpha- good to see you over here. We've talked on NAXJA. What ratio would you reccommend for that formula?? I'm gonna have to give that a shot if this overnight soak doesn't help. I've made progess in busting the rust crud out from around the remainder of the plug, we'll see how this overnight soak in PB does.
  14. This is the portion that is stuck in: So if you notice the portion UNDER the threads is what I am tyrying to break loose at this point. It looks to be pretty well rusted in there and that is the stuff I am soaking/cleaning around/prying on/torching. I am gonna try torching then the PB to shrink it. It seems soaking it has made it easier to bust some of the crud loose. This will be a trial in patience for sure.
  15. Oh also got the arched MJ leaves in from Tom at Hell Creek. I've been hitting all the hardware on the rear suspension with PB blaster the past two days in prep for the installation. They have great customer service and he's quick. If you don't hear from me by phone Tom, thanks again! :clapping:
