yamamatt Posted April 20, 2010 Posted April 20, 2010 New to MJ's and new to CC. I am going to do a cluster swap in my 90 MJ. My question is which year should I look for with out idiot lights(I want gauges)? Thanks any info will help. Matt
88pioneer Posted April 20, 2010 Posted April 20, 2010 Nothing later than 90. I know 86 and earlier won't work, and for some reason i think there is something with 87 that won't work but not sure.
87Chief Posted April 20, 2010 Posted April 20, 2010 As stated above, nothing earlier than '86... I got a replacement for my '87 at my local u-pull-it, It came from a '89 Cherokee... Pics: The back of your cluster, SHOULD look like that... I'm not sure though, someone might chime in and correct me... Hope this helps. 8)
deziped Posted April 20, 2010 Posted April 20, 2010 Use an 87 - 90. This is pic of an 86 and the speedo connection is a little diff. Image Not Found Image Not Found
yamamatt Posted April 20, 2010 Author Posted April 20, 2010 Thanks alot :bowdown: Going to pull-a-part this weekend to see what they have. Thanks Again
yamamatt Posted May 5, 2010 Author Posted May 5, 2010 Did the cluster swap but now the tach is a little off, is there a way to adjust it? THANKS
1987Comanche Posted May 5, 2010 Posted May 5, 2010 There's a pot in the tach. Pull the tach from the cluster and you can carefully adjust it with a screwdriver. FYI the Red/White/Black cluster pictured is called the Highline Cluster.
BORDENCOMANCHE Posted May 5, 2010 Posted May 5, 2010 I did the cluster swap, everything bolted right in and the gauges worked immeadiately all except for the oil pressure one, any ideas why? All it does is immeadiately pin itself out.
yamamatt Posted May 5, 2010 Author Posted May 5, 2010 I did the cluster swap, everything bolted right in and the gauges worked immeadiately all except for the oil pressure one, any ideas why? All it does is immeadiately pin itself out. My gauge does that also but is unplugged because I don't have the sender yet.
yamamatt Posted May 5, 2010 Author Posted May 5, 2010 Did the cluster swap but now the tach is a little off, is there a way to adjust it? THANKS Also my MJ is a 4.0 and the XJ the cluster came from was a 4.0. So I thought the tach would work correctly.
88pioneer Posted May 5, 2010 Posted May 5, 2010 I did the cluster swap, everything bolted right in and the gauges worked immeadiately all except for the oil pressure one, any ideas why? All it does is immeadiately pin itself out. oil pressure sensor
Eagle Posted May 5, 2010 Posted May 5, 2010 Did the cluster swap but now the tach is a little off, is there a way to adjust it? THANKS Also my MJ is a 4.0 and the XJ the cluster came from was a 4.0. So I thought the tach would work correctly. It should. How do you know it's off? How much is it off?
yamamatt Posted May 5, 2010 Author Posted May 5, 2010 Did the cluster swap but now the tach is a little off, is there a way to adjust it? THANKS Also my MJ is a 4.0 and the XJ the cluster came from was a 4.0. So I thought the tach would work correctly. It should. How do you know it's off? How much is it off? At idle it reads below zero.
Eagle Posted May 5, 2010 Posted May 5, 2010 Did the cluster swap but now the tach is a little off, is there a way to adjust it? THANKS Also my MJ is a 4.0 and the XJ the cluster came from was a 4.0. So I thought the tach would work correctly. It should. How do you know it's off? How much is it off? At idle it reads below zero. That doesn't sound like "off" ... that sounds like "broken." Even if it came from a 4-cylinder donor, it would show a reading at idle, but instead or 650 (or so) RPM it would be indicating 975 (or so) RPM. You could try taking the tach out of the cluster and adjusting the potentiometer on the back, but I'm not optimistic that it'll have enough adjustment to fix this. If you can get it to read accurately at idle, be sure to cross-check at around 2000 RPM, because it may be off there, as well.
yamamatt Posted May 6, 2010 Author Posted May 6, 2010 Is it possible that the needle was pulled off and put back on? Are they keyed or splined ?
Geonovast Posted May 6, 2010 Posted May 6, 2010 Is it possible that the needle was pulled off and put back on?Are they keyed or splined ? I don't think it's feasible to pull the needle off without breaking. At least, I've never been able to pop one off.
yamamatt Posted May 9, 2010 Author Posted May 9, 2010 Ok guys I fix my tach, I took the clear face off and manually moved the needle to max rpm and it would not max out so with a little force I moved it so it would max out and now the needle starts out at zero rpm's. Now when I start the engine it works like it should. Also put the oil sender in and the oil guage works too. Thanks for everyone's help.
yamamatt Posted May 9, 2010 Author Posted May 9, 2010 Went to idiot-zone to get a temp sender for the swap, the computer genius said there was not one for that vehical (90XJ) so after telling him that the computer was wrong and he insisted that it did not use one, so I asked him how a gauge works without one --- and still nothing. So does anyone have a part # for the temp sender, who knows maybe I am the idiot.
mvusse Posted May 9, 2010 Posted May 9, 2010 I think this should be it: Everco part number 36400 http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?categoryDisplayName=Climate+Control&fromType=parts&fromString=search&parentId=52-0¤tPage=1&filterByKeyWord=coolant+temperature&isSearchByPartNumber=false&navValue=15200113&categoryNValue=15299999&fromWhere=&itemId=113-0&displayName=Coolant+Temperature+Sensor&searchText=coolant+temperature Or from Advance BWD part number WT5011: http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Coolant-Temperature-Sensor-BWD_3461572-P_290_R|GRPSENSAMS_529634046___# Don't know if the links will work for you because there may be cookies involved
Eagle Posted May 9, 2010 Posted May 9, 2010 The Auto Zone link makes you reselect the vehicle, but does take you to the part. Unfortuntately, the photo shows a sender with a pigtail, so it may well be the wrong part. NAPA Online has it. You have to search for "Temperature Sender," not "sensor." The one for the gauge is Echlin #ECH TS6053
mvusse Posted May 9, 2010 Posted May 9, 2010 Turns out of links I posted are for the ECM. Advance does carry one for the gauge, and it looks like the NAPA one, Autozone does not seem to. BWD WT761 http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Engine-Temperature-Sending-Unit-with-Gauge-BWD_5973805-P_425_R|GRPSESWAMS_547252873___
