mike87mj Posted April 16, 2010 Share Posted April 16, 2010 ok so now that i have for the most part worked out all the bugs in the motor its onto the lift. so here's a few questions will xj lift kits fit on a comanche? i have a 2x4 comanche and might have a donor jeep (xj) for transmission/transfercase/and front axle will these bolt in with minor adjustments? i saw on another post that a soa will get about 5-7" in the rear the potential lift from the xj is a 4.5" lift. can the xj leafs be run on my axle without soa? if i did soa and xj 4.5 leafs (if they will fit) what am i lookin at needin for the front? the lift has uppers/lowers trackbar shocks and 4.5 coils. school me please i need all the info i canget i wanna do this once and be done with it don't wanna play the inch game Link to comment Share on other sites More sharing options...
jimoshel Posted April 16, 2010 Share Posted April 16, 2010 Your XJ trans, TC and FA will bolt right up. The rear springs will not. To use the rear axle you have to move the spring perches. Link to comment Share on other sites More sharing options...
88pioneer Posted April 16, 2010 Share Posted April 16, 2010 Yea, xj leaves are different and so are the perches. The specs on both your truck and the donor would help a lot answer some questions, (year, motor, trans, etc.) Link to comment Share on other sites More sharing options...
Geonovast Posted April 16, 2010 Share Posted April 16, 2010 The leaves do not care about SUA or SOA. There's no difference in that respect. SOA or SUA is entirely dependant on perch location on the axle. The XJ leaves will not work because they're much shorter than MJ leaves. All the front lift stuff, however, will bolt right onto your MJ. Link to comment Share on other sites More sharing options...
mike87mj Posted April 17, 2010 Author Share Posted April 17, 2010 sorry its a 87 mj 4.o 2x4 auto(don't know what sorry) and the xj is a 89 4.0 auto not sure again sorry i had a guy tell me the transfer case was a np231 on the xj if that helps. :dunno: so thanks for the info on the leafs will have to shop around I'm thinkin any good companys to look at? does anyone make a 4link for the rear and would it be worth doing that? i also have some zj lifts coils for the front 4.5 lift they were free and was told they would actually help keep the lift if a bumper and winch were installed does this sound right? and is it safe to run those? Link to comment Share on other sites More sharing options...
mnkyboy Posted April 17, 2010 Share Posted April 17, 2010 why not use your existing springs in the rear? with a SOA using 2wd leaves and an XJ 4.5" lift in the front the truck would probably sit pretty level Link to comment Share on other sites More sharing options...
mike87mj Posted April 17, 2010 Author Share Posted April 17, 2010 why not use your existing springs in the rear? with a SOA using 2wd leaves and an XJ 4.5" lift in the front the truck would probably sit pretty level will the stock springs give enough flex? i think that would probably work good and my leafs look to be in surprisingly good shape the rear seems to ride higher than the front already. what does eveyone think about the tera flex revolver shackles? Link to comment Share on other sites More sharing options...
Pete M Posted April 17, 2010 Share Posted April 17, 2010 revolver shackles are gimmicy and can be problematic if they unload under heavy braking. stock MJ leafs in an SOA setup do NOT need and assistance in the flex category. They are awesome. :thumbsup: Link to comment Share on other sites More sharing options...
mnkyboy Posted April 17, 2010 Share Posted April 17, 2010 why not use your existing springs in the rear? with a SOA using 2wd leaves and an XJ 4.5" lift in the front the truck would probably sit pretty level will the stock springs give enough flex? i think that would probably work good and my leafs look to be in surprisingly good shape the rear seems to ride higher than the front already. what does eveyone think about the tera flex revolver shackles? here's mine SOA with stock 4X4 rear springs yours should flex about the same,i run out of shock before the springs finish flexing. Link to comment Share on other sites More sharing options...
mike87mj Posted April 17, 2010 Author Share Posted April 17, 2010 :drool: i like the look of that now to find me some long arms! hey maybe a stupid question but when i do the soa do i need to get new perches? shock mounts? or can they just be reused? here's mine SOA with stock 4X4 rear springs yours should flex about the same,i run out of shock before the springs finish flexing how much travel should the shocks have to get the full amount? Link to comment Share on other sites More sharing options...
Pete M Posted April 17, 2010 Share Posted April 17, 2010 the answer to all of the above is: it depends. Link to comment Share on other sites More sharing options...
mnkyboy Posted April 17, 2010 Share Posted April 17, 2010 :drool: i like the look of that now to find me some long arms! hey maybe a stupid question but when i do the soa do i need to get new perches? shock mounts? or can they just be reused? here's mine SOA with stock 4X4 rear springs yours should flex about the same,i run out of shock before the springs finish flexing how much travel should the shocks have to get the full amount? yes you need new perches,i suggest longer ones to help with spring wrap. you will also need to come up with new shock mounts. or you can go the lazy route and just buy a bolt on SOA they are like $110 and come with everything you need besides shocks,just bolt it in and go. Link to comment Share on other sites More sharing options...
mike87mj Posted April 17, 2010 Author Share Posted April 17, 2010 :drool: i like the look of that now to find me some long arms! hey maybe a stupid question but when i do the soa do i need to get new perches? shock mounts? or can they just be reused? here's mine SOA with stock 4X4 rear springs yours should flex about the same,i run out of shock before the springs finish flexing how much travel should the shocks have to get the full amount? yes you need new perches,i suggest longer ones to help with spring wrap. you will also need to come up with new shock mounts. or you can go the lazy route and just buy a bolt on SOA they are like $110 and come with everything you need besides shocks,just bolt it in and go. ya but if i go that direction the wife can't yell at me for burning myself with the welder and thats just not fun :rotfl2: Link to comment Share on other sites More sharing options...
