If you're going to start a new thread, you may want to recap what you've done so far. :thumbsup:
I just fought this on my 88. I replaced the thermostat, flushed the radiator and dug all the bugs out. I replaced the bottle and cap as it would boil over, none of this worked.
I finally went to Advance and bought a replacement radiator for 99 bucks. Problem solved, I guess after 240k miles I was due. Then that one started to leak but they had a lifetime warranty so I did it again no problems thus far. I wished I had done this earlier.
I have a 00 4.7v8 grand cherokee that I fought overheating issues after taking it in to the shop for some work. Turns out somehow when they flushed the system they clogged up the radiator. Long story short everything in the cooling system was replaced before I ended up putting in a new radiator. It turned out to be a plugged radiator.
