2.5 questions...update 5/20/2010
i said easiest way not the best way.
really unless your building a race car or plan to run alot of boost i don't think you would notice a difference,most OEM carb/turbo setups are draw through.
I have seen VWs get into the 10s running draw though,its common on aircooled VWs for its simplicity.
When i build a system i usually convert to MPFI and go blow through.
  • 1 month later...
WOW, it's been awhile for this thread. Anyhow I got the truck here and found that the valves has been coated with bad gas that turned to varnish on the stems. So I removed the head and had a valve job done. I got the head back on and all buttoned up. Now I found that someone "borrowed" the electronics form the distributor :fs1: . The engine was replaced in '02 w/a MOPAR reman. This thing was SPOTLESS on the inside,the crosshatch pattern is stil very vissable on the cylinders,and the tops of the pistons had almost no carbon on them! I can even see the .005 oversize on them. :D . So after I hit the wrecking yards this weekend, I may be able to have it running! :clapping: AFTER I clean the fuel system out and replace the filter.
-Lance
ok my 2 cents
i am running a tbi 2.5 cone air cleaner up thru the hood with a scoop on it
bored .040 over
open exaust with flow thru cherry bomb
4 speed
3.55's
4X4
added p/s
and i can smoke my 31 mt's on black top and climb anything i want no problum
:cheers:
