comanche09 Posted March 7, 2010 Share Posted March 7, 2010 Hey All, First thank you to mnkyboy and flyn2er for offering their experiences and tips. :cheers: These seats are from a 2007 (Passenger and Center) and 2006 (Driver) Mitsubishi Raider (Dakota Clone). I chose these because it seems you can't get the 05+ Dak seats in Black. They are SUPER comfortable and light years ahead of the original vinyl bench (as they should be) :brows: Thought I would share my install: I fabbed in the cupholder from a 2000 Dakota center seat. This is a close-up of the driverside front bracket. The driverside was the most difficult to fab in as you don't have alot of space to work with due to the hump/tunnel. For the rear, I bolted in the stock Dak rear bracket through the floor with a big carriage bolt. Had to repair the donor bracket (it was rusted away on one side), but this is another pic of the drivers side. Passenger side was much easier, I used the stock Manche brackets as a base. For the center console, I cut the Dak brackets, bent em a little, positioned em and bolted it through the tunnel. Back console bolts, I know about the washers, I was using hardware I had in my garage. I will get the right length bolt in there. :dunce: Front console bolts. Rear drivers side seat bolt. :cheers: Link to comment Share on other sites More sharing options...
avnsteve Posted March 7, 2010 Share Posted March 7, 2010 those look really nice, I may consider that option as my bench sux right not, and I just put new floors in, I can still fab up any mount arrangement i want/need. thanks Link to comment Share on other sites More sharing options...
vaquaro Posted March 7, 2010 Share Posted March 7, 2010 Nice choice on 40-20-40 seat , kinda best of both worlds . I may finaly be inspired to get on with my "some-day " seat project :idea: ( just a thought....some larger 3" washers would be a lot safer on those seat-belt bolts ) :thumbsup: Link to comment Share on other sites More sharing options...
Drahcir495 Posted March 7, 2010 Share Posted March 7, 2010 ( just a thought....some larger 3" washers would be a lot safer on those seat-belt bolts ) :thumbsup: :agree: That was the only thing I would have suggested. It looks really nice in there - great job! Link to comment Share on other sites More sharing options...
comanche09 Posted March 8, 2010 Author Share Posted March 8, 2010 Thanks! :cheers: The seat belts are not attached to the seats. They are attached to their factory locations. That's one of the beauties of an MJ seat swap. Link to comment Share on other sites More sharing options...
flyn2er Posted March 8, 2010 Share Posted March 8, 2010 Looks good. I still don't have mine finished but i need to try to drop them down. Good choice on seats. Link to comment Share on other sites More sharing options...
A-man930 Posted March 8, 2010 Share Posted March 8, 2010 the part I'm most intrigued about is that center console... :idea: Link to comment Share on other sites More sharing options...
mnkyboy Posted March 8, 2010 Share Posted March 8, 2010 you lucked out :thumbsup: When i got my MJ it had some rotten buckets out of some car bolted to wooden blocks attached to the floor,my Dakota seats came with no brackets so i pretty much fabricated everything. looks like having all the brackets helped a bit. looks good though :cheers: Link to comment Share on other sites More sharing options...
