knever3 Posted March 6, 2010 Share Posted March 6, 2010 What adhesive tape do you use when installing the Comanche badge, 4x4 badge, 4.0 litre badge and the PINNED JEEP hood badges? Brand or direct links would help instead of just genaric terms. Do you use glue on the Hood JEEP or adhesive? Thanks! Link to comment Share on other sites More sharing options...
64 Cheyenne Posted March 6, 2010 Share Posted March 6, 2010 http://www.shop3m.com/3m-trim-adhesives-hhsn5p5fgr.html Link to comment Share on other sites More sharing options...
Geonovast Posted March 6, 2010 Share Posted March 6, 2010 I've used the 3M stuff specifically for auto badges. Works pretty good. Link to comment Share on other sites More sharing options...
bighause Posted March 6, 2010 Share Posted March 6, 2010 I used black RTV sealant for mine, but then again my truck is a piece with a crappy paint job. The badge is not coming off and you can't tell it isn't factory. Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 6, 2010 Share Posted March 6, 2010 3M tape here too, works very well. It comes in various widths and is available at any car parts store. The JEEP emblem is either held on by nuts if it's a '90 or earlier or adhesive (tape?) if '91 or '92. The tape is also used to hold on the side molding if you have it. Link to comment Share on other sites More sharing options...
knever3 Posted March 6, 2010 Author Share Posted March 6, 2010 3M tape here too, works very well. It comes in various widths and is available at any car parts store. The JEEP emblem is either held on by nuts if it's a '90 or earlier or adhesive (tape?) if '91 or '92. The tape is also used to hold on the side molding if you have it. Nuts??? are they the flat steel speed nuts? If so I will have to buy those too, thanks for the response all"! Link to comment Share on other sites More sharing options...
dasbulliwagen Posted March 6, 2010 Share Posted March 6, 2010 Yes 3M, don't use the adhesive glue meant for emblems, at least not on your own vehicle. The 3M emblem adhesive I used to use when doing body work was good stuff, but don't screw it up as it will eat into your paint job... part of what made it hold so well I guess! At least with the tape, if you screw it up, you can pull it off, and re do it if needed. Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 6, 2010 Share Posted March 6, 2010 The JEEP emblem is either held on by nuts if it's a '90 or earlier or adhesive (tape?) if '91 or '92. Nuts??? are they the flat steel speed nuts? If so I will have to buy those too, thanks for the response all"! Yup, that's them. Link to comment Share on other sites More sharing options...
