I'm new, just got my first 1988 comanche for $500, and the opportunity has arisen to buy a 1986 with a non-working engine just for parts. I am wondering what parts do not directly swap from an 86 to an 88
Essentially everything can be swapped over. The main differences are the radiator core support and hood are different. They can be swapped, but it would be taking a step backwards in safety, as the '86 used a center mounted latch system and the '87+ used one latch on each corner of the hood. If the motor/trans setup is the same, most everything is interchangable as well. In other words, if it's a good deal, GRAB IT and don't second guess yourself.
what are the engine/tranny combos in each truck?
I'm more talking about body parts, the bed on mine is pretty rusty and the new one is in good shape.
Oh, cool. Yeah - what beaterjeep said, the vast majority of body and interior parts from the cab forward will swap over, besides the difference in the hood & rad support like he mentioned.
But all '86's were long beds. If the '88 is also, then the swap should be easy. If the '88 is a shortbed, I'm not sure how involved it is. They're different wheelbases.
