I second using the Rubicon Express drop brackets and short arms. Bolts in without cutting up your truck. :D There are plenty of guys that prefer longarms and I'm sure they'll chime in. :brows:
If you go over 4.5 inches you should use drop brackets or go long arms. That’s why I decided against going SOA $$$
naa don't need to really....
I have planned to use RE 3720 and RE3781. I will not use drop brackets. If I don't like it I will make my own drop brackets.
i would get the RE3715 they only $50 more and the flex joint is rebuildable.....just my opinion...
  • 4 weeks later...
I have used both Lo0ng arms and the RE drop brackets. The RE Db's flex really good for what they are, and ride nice. LA's work good as well too, since You are against Db's go with Long arms.
at that height you should consider drop brackets, or longarms.
I'd recommend RE for the drop brackets. and RE adjustable arms.
I agree.
